GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - Flat Battery - Won't come out of gear
Old 21st June 2019, 12:51 PM   #13 (permalink)
SKNAM
SKNAM is unaware they can edit their status
The moving part of the steering locks are electro-mechanical (i.e. have some sort of actuator in them to operate the "lock") so I don't think you'll be able to get it to operate without ignition, unless someones found a work-around.
Just a thought, do the crash sensors have a dedicated fuse/relay? If so, would removing that enable you to turn on ignition? ECU might throw a code, but that could be deleted later on etc.
SKNAM is offline   Reply With Quote
