GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - A tale of two Skylines.
Old 28th June 2019, 11:24 AM   #204 (permalink)
Red Duke
Red Duke's Avatar
Originally Posted by profaine View Post
Pulling the front end off and seeing that rust would be a harrowing sight but glad to see it is all getting dealt with!
I like the cooling panel mod, I hope to do the same one day!
Good read, thanks.
Thanks Profaine
Yes it was a bit of a shock, it was mostly in the corners where there is little to no protection from the factory, having been in the UK for over a decade now I'm glad it wasn't worse! Inside the driver side chassis opening was actually a greasy dirt build up! Cleaning that away revealed little to no rust at all, the passenger side was worse as it had little covering of anything. I do wonder if the hole in the passenger wheel arch liner (for the oil cooler) has made it worse. Just had my new lambda sensors arrive so I can get on with those and the rear turbo install, at last!
