Lets talk GTR boxes and diffs shall we... - Page 4 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 22nd August 2006, 01:08 AM   #61 (permalink)
Bateman is unaware they can edit their status
Originally Posted by tyndago
They are not really torque limiters in as much torque split controllers. The thing you want to do is limit torque to the front wheels. Sooner or later, big power GT-R's break the front diff. Break front axles. Break front propshaft.
The best way to remedy it, rather than just make everything stronger, is to limit the torque going to the front wheels.
The hydraulic levers just take the electric pump out of it. Less parts to fail. Less weight.
Lock up the center diff like a AWD car. Its what seems to work best for drag racing.
But if you lock up the center diff so it constantly is 50/50 that means is will put more load on the front diff, will that last very long at all really?
Bateman is offline   Reply With Quote
Old 22nd August 2006, 04:58 AM   #62 (permalink)
tyndago is gtrusablog.com
tyndago's Avatar
Cars owned: Nismo R32, #500, and #536
Theres no way a GT-R transfer case can actually do 50/50. It might say it on the gage, it might say it in the books, but in real life...
I actually should have said - partially lock up the center diff. Or put enough pressure on the center clutch pack to provide power, but not enough to snap parts.
Sean Morris
Old 22nd August 2006, 08:36 AM   #63 (permalink)
keith is TEAM COWIE R35
keith's Avatar
Cars owned: R32 Gtr Drag Car. R32 Gtr Track Car. R35 Gtr Road Car.
If you use a system like this and pump the pressure up enough
it will lock up the clutch pack in a 50/50 split and yes it was bust the diff
Been there and done it
Team Cowie
Its all about corners now
keith is offline   Reply With Quote
Old 26th September 2006, 10:27 AM   #64 (permalink)
RocK is a racer..
RocK's Avatar
Cars owned: BCNR33 V-Spec
for years I been dying to ask someone (who speak english) about this 2nd handbrake system. when i asked JUN about it, i couldn't understand its procedure.
he was saying "before burnout, we do this this. after burnout we do this, just before lauch we do this this." someway in between he said "pump this and lock this" i was lost when he was at his 1st "this"
Mr.Keith, can you school me on this.. pls..
oh btw tyndago, you need to ungrade your transfer case too to do 50/50 split. or it will just slip
HKS GT3240 x2 (sold)
HKS F-Con V Pro (Tuned by Susumo Koyama)
JUN Full Head System + JUN 2.7L (ko)
HKS 6 Speed + OS Triple Plate Clutch
Greddy 4 Layer Intercooler
RocK is offline   Reply With Quote
Old 26th September 2006, 06:14 PM   #65 (permalink)
tyndago's Avatar
You do not want to lock the transfer case at 50:50. If you do, you will break the front diff, front axles, and front driveshaft.
You only want to send about 20 percent or so to the front on a big power car. Anymore, and you will break parts on every pass.
Sean Morris
Old 27th September 2006, 04:03 AM   #66 (permalink)
RocK is a racer..
RocK's Avatar
yep. we have upgraded the diff with nismo 4.4 and running hks shaft. no so sure the axle can be upgrade.
just notice Keith is a banned member here. ah... anyone know about the 2nd handbrake system?
Old 27th September 2006, 08:34 AM   #67 (permalink)
Hugh Keir is getting old
Hugh Keir's Avatar
Cars owned: R32 GTR Race Car
What is it you would like to know
Old 27th September 2006, 09:51 AM   #68 (permalink)
ATCO is advancing with Blue Streak
ATCO's Avatar
Cars owned: GTR34, GTR33, GTR32, Golf Diesel, GT750x2
The lever is used as a simple pump to pressurise through a valve the clutch pack on the transfer box. You need to fit a good pressure guage and a return route valve to release the pressure as you don't need 4WD all the way. The return valve should be solenoid driven, triggered by the EMS.
Keith told me what the maximum pressure you should use is without breaking the front diff, however it may be one of his "secrets", perhaps Hugh can check with him if he minds releasing the "knowledge".
DaveG
"never attribute to malice that which can be explained by stupidity"
2016 JDS PRO, quickest time [email protected]
2015 JDS Street Class Champion, Former 4WD Top Speed and 1/4 mile time record holder!
2014 JDS Street Class Champion, RIPS Blue Streak
2013 JDS Street Class Champion, RIPS Blue Streak
2012 10th in JDS Street
2011 4th Jap Drag Series Street
2010: Car broken
2009 6th HKS Series
2008: 3rd= overall PRO Drag Series. 4th HKS Street Series
ATCO is offline   Reply With Quote
Old 28th September 2006, 06:10 AM   #69 (permalink)
RocK is a racer..
RocK's Avatar
so, zero/low pressure for burnout. ie RWD
then pump to the magic max pressure before launch. in that way?
when do we release the valve lock? dont we want it RWD pass 200m
anyone willing to draw a setup diagram?
Old 29th September 2006, 07:29 PM   #70 (permalink)
warbandit is unaware they can edit their status
i have a r32, but ist automatic, i what to change it to a manual box, i was wondering if someone could advise me, on the best one to get and were to get it.
warbandit is offline   Reply With Quote
Old 22nd October 2007, 01:36 PM   #71 (permalink)
Thrust is waking from hibernation
Thrust's Avatar
Cars owned: Tom's AristoV300, BNR 34, BCNR 33, Forester CrossSports
Question
Originally Posted by m6beg View Post
Yes. Then some clever man to do another switch so you can drive the car every day on the road.
Mick
Who is this clever man and is the switch available?
Can a car with a Holinger box be driven everyday in town?
All play and no work makes Jack a right berk. Spider Godwin
Action Group for the Ban against Skirts to be Lifted
Thrust is offline   Reply With Quote
Old 22nd October 2007, 04:24 PM   #72 (permalink)
TOMMO_GTR is unaware they can edit their status
how fast are you guys planning to go on the 1/4 mile...i dont know much but every time Rob form RIPS posts his signature says:
Street car: R32 GTS4, 100% stock unmodified internals, standard g/box, [email protected] 600+whp. Fastest street skyline in NZ.
Does anyone know how the hell he did that or what other transmission upgrades he had???
TOMMO_GTR is offline   Reply With Quote
Old 22nd October 2007, 05:28 PM   #73 (permalink)
GTR RGT is unaware they can edit their status
GTR RGT's Avatar
Cars owned: R34, R35, Defender, Supra
Yep, I know 2 GTR's that do so
GTR RGT is offline   Reply With Quote
Old 22nd October 2007, 08:31 PM   #74 (permalink)
tyndago's Avatar
Some people have more "LUCK" , than others. There a lot more people that break 3rd gear than make it into the 10's on a stock gearbox.
I've done both. Broke 3 standard gearboxes - 3rd gears in a month, and run 10's on a standard gearbox.
I have also worked on GT-R's for 8 years, and I see a lot more broken gearboxes at lower power levels, than guys going really fast. Rob got lucky, but sooner or later, the luck runs out, and all the teeth come off 3rd gear.
You can run a sprung hub clutch, you can run Redline Shockproof Heavy in the boxes. You can shift easy into 3rd. The same box I ran multiple 10 second passes on, a customer broke about a week later in his street car.
Sean Morris
Old 23rd October 2007, 02:32 AM   #75 (permalink)
Thrust's Avatar
Lightbulb
Take those sunglasses off and tell me more! You know two people who run Holingers/sequentials in everyday cars? Or you know two people with secret switches?
Old 24th October 2007, 09:34 AM   #76 (permalink)
R.I.P.S NZ is down to 7.28 @ 197mph worlds quickest skyline GTR
R.I.P.S NZ's Avatar
Cars owned: R32 GTS4
There were no modifications to the box, axles, diffs etc, all old used stock parts with shockproof oil in the box and "tip toe" into 3rd.
I was able to run 10.50-10.70 time after time and had a real good run from an old stock box, wind the power up enough to run low 10's and it would strip 3rd more often than not.
With a box I could have been savage on and use all the power we had I'm sure it would have run 9's.
This was with a 300,000km old stock internal bottom end, stock RB25de N/A head, stock N/A cams, stock RB20det cast exhaust manifold etc so it would have been good to get a decent box in it just once to get a 9.
The only thing in the driveline that wasn't old and totally stock was the flywheel/clutch.
Rob
RIPS is NZDRA Champion 2010/2011/2012, IHRA Champion 2011/2012
Worlds quickest and fastest RB30 6.99 and 192.7mph on the 1/4
CC/D, DD/D and EE/D NZ record holders and multiple track record holders with a street based RB30
Mild to wild RB30s, 7,8,9,10 sec street/drag cars built to order, custom fabrication, worldwide shipping
e-mail
Old 24th October 2007, 11:37 AM   #77 (permalink)
Rob
RIPS = LEGEND!
Old 24th October 2007, 05:18 PM   #78 (permalink)
tyndago's Avatar
So then would you say if you stuck someone else in your car, and they drove it down the dragstrip, that they would be as likely to break the box, as make a full pass ?
Seriously Rob. I know you went fast on a stock box, but there are many more people that break 3rd gear well before they make a 10 second pass.
On one gearbox, I run a ton of 10 and 11 second passes, loan the exact box to a customer with a 500 whp car, and he breaks it the 2nd day he is driving on the street. With me driving a 600 whp R33 - 10 and 11 second passes, with him driving, shears all the teeth off.
Sean Morris
Old 24th October 2007, 08:03 PM   #79 (permalink)
R.I.P.S NZ's Avatar
Sean, maybe some poeple need to learn to drive a little better/smoother then, being overly agressive and smashing it through the gears is not the way to go fast in any case.
Here's the car with the stock motor, stock box etc and the 10.2:
http://www.ripsltd.com/performance/video/RIPS_GTS4.mpg
Rob
e-mail
Old 24th October 2007, 08:35 PM   #80 (permalink)
tyndago's Avatar
Have you EVER broken a GT-R/GTS transmission ?
Has any of your customers EVER broken a GT-R or GTS transmission ?
We can sit and say to drive smoother, but its not going to happen.
After breaking 3 in a row, I made sure I was smooth and easy on 3rd gear. Most owners will give up after the first box, and want something else that won't break.
This is why OS Giken gearsets, Pfizner gearsets, Quaiffe gearsets, Holinger sequentials, OS Giken sequentials all exist for a GT-R. They exist because the stock stuff breaks. It exists because most owners will break it, and when they do, they want more. They don't want to stick with the stock parts that break.
Its like front diffs, you said before you hadn't broken one, thats fine, but I have , and a number of customers have on the street.
Ignoring the issues, and saying that stock is fine is not the answer. It needs to be realistically discussed with people that don't want to break things.
Everything is a link in a long chain of parts. I make recommendations to people based on what I see, and what I have seen. I am realistic, and I expect my explanations to be realistic.
A customer is a lot more likely to break a transmission going for a 10 second pass, than make a 10 second pass with a stock transmission.
Sean Morris
