Fueling: R32 GTR 1.5bar 2860-5's - Page 6 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 20th February 2009, 10:49 AM   #101 (permalink)
ExScoobyT is unaware they can edit their status
Cars owned: R33 GTR V-spec, AW11, 200SX, RAV4
If you pass a given mass flow of gas down a pipe at pressure, it comes out the end of the pipe at a lower pressure than it went in at. This is due to boundary layer friction effect and turbulence in the flow.
For the same mass flow and pressure, increasing pipe diameter decreases the pressure loss. Reducing the acuteness of bends and improving the bend radius to pipe diameter relationship all help pressure drop.
This is why you use larger pipes with higher mass flows and pressures. This is why a lower loss air filter makes more power. This is why larger throttle bodies are used, its why the Nismo high pressure pipework is soooooo nice, its why the GTR shop baffled twin-turbo pipe should make more power etc etc etc
The compressor is pulling air through the air filters, MAFS, low pressure pipe work etc etc. This results in an intake depression infront of compressor (Negative pressure). The compressor then does work on the gas to increase its pressure (and temp). This high pressure gas is then transported down the high pressure pipework, through the I/C where it is cooled (some additional pressure loss due to the cooling effect), through the throttle plate and into the manifold, then through throttle bodies, past valves into combustion chamber.
So, in your example where you are running the turbo at 1.6bar boost:
Pressure in intake manifold: 1.6bar
Pressure at hot side of I/C: ~ 1.8bar
Pressure at compressor outlet: ~1.9bar
Intake depression at compressor inlet: ~ -0.3bar
Therfore inorder to run 1.6bar at the intake manifold, you are actually running the compressor / turbine assembly at 2.2bar. Not good.
Don`t forget; higher compressor work requires more energy to be supplied from the turbine. More energy from turbine is higher pre-turbine pressure which results in lower volumetric effeciency across the head, more trapped residual, more intake charge heating and a lower knock threshold.
Old 20th February 2009, 10:56 AM   #102 (permalink)
Adam Kindness is phu phu phu
Adam Kindness's Avatar
ok... so possible factors..
Air Filters (they are shite, old, unmatched, dirty)
FMIC - Standard, old, and a bit dented
shitty intake pipes/bends (most are standard plastic ones)
- Sponsored by Ultralite &
'81 Porsche 911 SC 3.0
'08 Navara Outlaw
Old 20th February 2009, 12:40 PM   #103 (permalink)
cokey is cokey requires no Status
cokey's Avatar
Cars owned: r32gtr
Hi Adam.
Maybe your std rubber intake hoses are deforming a bit at the top end and disturbing the airflow at the inlet ?
Just a thought.
cokey
Quote "Itís GT-R lore now that the 1989 - 94 BNR32 GT-R sold at a loss for about 5,000,000 yen, when in actual fact it cost 12,000,000 yen to produce"
Cool, but they are clawing it back now.
"Faith is a personal thing, that you may share but not enforce or inflict." Jae
Old 20th February 2009, 01:30 PM   #104 (permalink)
yup....
I think there are several factors.... the turbos are sucking through soggy teabags (old dirty filters) - then pushing the air through an old crapy IC via some rubber IC pipes. (I know that the psgr side rubber IC pipe has its outer cover removed too)
'08 Navara Outlaw
Old 20th February 2009, 01:32 PM   #105 (permalink)
Listerofsmeg is unaware they can edit their status
Listerofsmeg's Avatar
Cars owned: Honda Civic/Audi A8
defintely get some jubilee clips round that pipe...and the other side.
Youve got me thinking that i really should change all my intake pipework to metal now...
Old 20th February 2009, 03:48 PM   #106 (permalink)
Fee Kindness is unaware they can edit their status
Fee Kindness's Avatar
Cars owned: Impreza, R32 GTR, Porsche, Range Rover (Corsa if I have to!)
Money money money!
We should have asked for car parts as wedding presents!!!
I did feel a vast improvement in it driving it home yesterday. power kicks in a lot quicker...a lot faster take off from standstill / roundabouts etc.
Certainly put a smile on my face!
R32 GTR Trackcar
Fee Kindness is offline   Reply With Quote
Old 20th February 2009, 05:53 PM   #107 (permalink)
sort out getting those induction kits then!! :P
Puma Race Engines Tuning Guide - Tuning Turbo Engines
'08 Navara Outlaw
Old 20th February 2009, 10:13 PM   #108 (permalink)
GT-R Glenn's Avatar
Take the air filter off completely next time you dyno it,
I had trouble with mine a long time ago, took the filters off and got like 40 hp .....went round to soichi's and got 2 new apexi ones.
Definately was holding it back
Old 21st February 2009, 07:25 AM   #109 (permalink)
yup, I'm actually very interested in the back to back dyno's now to see how much these parts effect the power.
I'm not willing to spend £1800 on a bling brand lable IC though.
'08 Navara Outlaw
Old 21st February 2009, 10:40 AM   #110 (permalink)
think i said to try that earlier on, its definitely worth a go....given that you can on a d-jetro...
Old 21st February 2009, 07:20 PM   #111 (permalink)
yup.... The car's not doing much just now anyway so will give it a bash when we source/get new filters
'08 Navara Outlaw
Old 21st April 2009, 04:59 PM   #112 (permalink)
professor matt is unleashing Godzilla
professor matt's Avatar
Cars owned: R35 GTR BLACK EDITION R34 GTR V-SPEC/TURBOCHARGED 5 & 3 SERIES BMW
how did you get on with your fueling adam?
professor matt is offline   Reply With Quote
Old 6th May 2009, 10:31 AM   #113 (permalink)
:S there wasnt anything wrong with the fueling.
We are now running a 2l surge tank, with dual Bosch pumps (Tomei pickup pump) to a twin entry rail (-6 braided lines) and 800cc Injectors.
Also have a HEL fuel sampling kit in line now too.
'08 Navara Outlaw
