GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - Nissan employee & VR38 engine details
Old 16th November 2007, 11:00 AM   #13 (permalink)
Wink
Wink is unaware they can edit their status
Oh yes, King Nismo and bonzelite, check all my other posts to see if I'm a man who should know or not.
A few other snippet for you monkeys....
Piston pin diameter 23mm
Piston compression height 32.5mm
Counterweight radius 94.5mm (limits max capacity to 3.8L with fixed bay balance)
Max oil flow 60 l/min (although the pump delivers 120l/min at 6800 rpm, but obviously most of it is relieved by the PRV).
Max heat-to-oil (at VMax) approx 34 kW (which is why there is a bloody big oil cooler mounted in the fog light position
Max water flow approx 300 l/min (the VQ35 max water flow is only 180 l/min), with max heat-to-water of 137 kW
Max heat-to-air (for intercoolers) approx 41 kW......!
Wink is offline   Reply With Quote
