R32 GTR Weight Loss Program - Page 16 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree2Likes
Old 10th January 2013, 11:41 PM   #301 (permalink)
tarmac terror's Avatar
Originally Posted by carbonfootprint View Post
As I said earlier, much much stronger composite doors as opposed to skins
Sorry, I really cant see how doors made from carbon/kevlar/glassfibre or any of the more exotic composites can make up for the R32's inherent lack of integrity in a side impact. You can strengthen doors until you're blue in the face, but that wont make up for the gossamer-like sills or B-pillar area.
TT
Old 10th January 2013, 11:58 PM   #302 (permalink)
Sub Boy is a nana driver
Sub Boy's Avatar
TT
^^ What he said, Better off putting in a nice Cromo-Steel Cage and running super light doors, Improve the handling of the car, and give you crash protection.
Old 11th January 2013, 12:54 AM   #303 (permalink)
infamous_t's Avatar
Yep, save money on buying carbon doors, just gut the hell out of them (for weight savings) and run a decent cage for protection
Old 11th January 2013, 05:13 AM   #304 (permalink)
Adam Kindness is phu phu phu
Adam Kindness's Avatar
TT - how are those headlight blanks coming along?
- Sponsored by Ultralite &
'81 Porsche 911 SC 3.0
'08 Navara Outlaw
Old 11th January 2013, 10:05 AM   #305 (permalink)
carbonfootprint is unaware they can edit their status
Couldn't agree more. I guess what I was saying is you can make a composite door significantly stronger than stock with a steel bar in it but ultimately it needs a cage to stop intrusion. It still comes down to the chassis/pillars without it.
However if you don't want a cage but want stronger lighter doors it can be done.
carbonfootprint is offline   Reply With Quote
Old 26th January 2013, 06:20 PM   #306 (permalink)
Big Ash is unaware they can edit their status
Big Ash's Avatar
Cars owned: R32GTR R33GTST
Ive just removed my power steering rack today and I'm going to convert it to a manual rack. Will get a larger diameter steering wheel to help turn it. I'm going to remove the internal seals and replace the fluid with grease. This is the correct way to do it.
Will save alot of weight as no pump, reservoir or lines etc plus extra power not having to drive the pump.
If its too heavy I will install and electric steering column. At least I would have moved alot of weight rearwards if nothing else.
Big Ash is offline   Reply With Quote
Old 26th January 2013, 07:40 PM   #307 (permalink)
jasaircraft is building heat
jasaircraft's Avatar
I was thinking about the electric rack and steering too...
jasaircraft is offline   Reply With Quote
Old 26th January 2013, 10:50 PM   #308 (permalink)
Big Ash's Avatar
Ive done a few on VW campers but not looked into the Skyline yet. will do if I need to if the manual steering is too heavy.
Old 26th January 2013, 11:15 PM   #309 (permalink)
nick the tubman is feeling very pleased !
nick the tubman's Avatar
Cars owned: R35 GTR `10. R33 GTR v-spec Road & Track. R33 GTR Race Car
i went down the electric road... weighed the electric set up against the stock.. and the electric set up, complete, was heavier and more complicated than the hydraulic set up.
additionally, the electric pump suffered from overheating and sluggishness. so i have stuck with standard system and just installed a cooler. WAY better....
saying that,, porsche have gone all electric, but it is complicated and a very very expensive conversion - so personally, i dont get it...???
what is the benefit? other a slight reduction on power drain for the engine. almost negligable on a car producing over 600hp.
adding to that, lack of "feel"...
GTR = More smiles per mile, than any other...
nick the tubman is offline   Reply With Quote
Old 27th January 2013, 03:03 AM   #310 (permalink)
Is.the actual rack moved with hydraulic pressure from an electric pump or directly with an electric motor?
Maybe the mechanical one.is.better? Ligjter?
Old 27th January 2013, 10:13 AM   #311 (permalink)
Big Ash's Avatar
Which electric system did you use? Ive used Corsa column and reckon there is probably a slight weight saving using it but not much. I have one in my shed I shall weigh it later.
Corsa Columns have an electric motor in them like this.......
http://www.ebay.co.uk/itm/VAUXHALL-C...item3cce578f84
Old 19th February 2013, 09:59 PM   #312 (permalink)
just to remind all the whole hicas system (including brackets an bolts) on the 32 gtr is 18 kilos, this is without cutting the rear chamber of the pump, just removing its guts.
Old 20th February 2013, 10:24 PM   #313 (permalink)
Big Ash's Avatar
Ive just converted my power steering to rack to manual. Reckon its saved loads of weight... heres how I did it...
https://www.gtr.co.uk/forum/173149-po...onversion.html
If its too heavy I will put a corsa electric column on it but I reckon it will be ok. Will find out when I get it up and running in the next month or so.
Old 20th February 2013, 10:38 PM   #314 (permalink)
lightspeed is mapping Infinity
lightspeed's Avatar
Cars owned: Project BNR32
"saying that,, porsche have gone all electric, but it is complicated and a very very expensive conversion - so personally, i dont get it...???
what is the benefit? other a slight reduction on power drain for the engine"
CO emissions - no engine losses from PAS in a straight line.
Got to beat the Brussels eurocrats, 0.1hp at a time !!!
Old 28th February 2013, 10:27 PM   #315 (permalink)
For the record, I just removed one of the small 1/4 windows of my 32gtr and it only weighs 1.5kilos, so not sure its worth making them out of polycarb...
Old 1st March 2013, 09:28 PM   #316 (permalink)
freakazoid3 is a longtime addict
freakazoid3's Avatar
I cut the rear wall behind the rear seat out off my track 32, saved me a fair bit aswell, and I removed all unnecessary wires from the main loom and ran it down the middle off the car, could've made a fair bit off cash if I brought all the copper to a dismantler
R32 or R35 ?
Old 3rd March 2013, 12:17 AM   #317 (permalink)
Anyone know whats the rear windshield's weight?
Old 3rd March 2013, 11:20 AM   #318 (permalink)
You clearly haven't felt the weight of a polycarb rear 1/4!!! They effectively weigh bugger all so an easy 3kgs saved by the time you also take into account the standard trim and all the evil rubber/mastic sealant you MUST be over 5kgs!!.
Biggest shock for me so far has been replacing the std doors with composite and polycarb windows. I still cannot believe just HOW heavy the std doors are.....composite doors must save a monumental amount of weight!!
TT
Old 3rd March 2013, 03:40 PM   #319 (permalink)
I will cut the polycarb 4mm sheet i have to the 1/4 size... I think it will save just a kilo ...not sure if its worth
Agree on the doors I have made one only yet 20+ kilos taken away. I made one of the side windows 1k vs 5k stock glass.
Old 21st March 2013, 12:08 AM   #320 (permalink)
Need to get the car back on some scales, but it should be near 1300kg now..
ABS gone, carbon seat, a few things removed and will go round chopping some more...
'08 Navara Outlaw
