Is it normal for a 32 GTR to run at 0.5 bar as standard if it has uprated turbo's? I've been told the car has a set of N1 turbo's and when i turn my boost controller off it only boosts to half a bar though it still pulls hard. It says 0.5 on the boost controller and on the Apexi boost gauge.
If you have no leeks and boost controller off it will boost to 0.5bar if running the feed off the plenium. When I use a different feed further around the engine then the norm is 0.7bar when the boost controler is off on my car.
the actuators are set for .5 bar. you only acheive the standard .7 when the solonoid is plumbed in which bleeds of boost into the low pressure side of the system.
