Hi all - I'm looking at putting a Bosch 044 pump into my R33 GTR prior to getting the PFC installed and tuned (044's are going cheap atm). I'm trying to figure out if I should replace the standard pump with the 044 or use the standard pump as a lift pump directly into the 044 mounted in the boot (which means I can mount it externally and not faff around with modifying the cradle etc etc)
Logic tells me the latter option won't work as the standard pump won't be able to feed enough flow to the 044. However, logic also suggests that as the factory pump is now providing flow not pressure, it could well work....
I do not want to run a swirl pot (as I like my boot space as it is!)
btw, I've already bypassed the FPC, and in the latter scenario, I'd run both pumps off the same relay (unless someone can tell me how much current a standard pump and an 044 draw?)
Discuss.
Discuss.
