161 - 180 of 265 Posts
Factoring out "from new" depreciation its somewhat amusing to think a trip to the supermarket and back costs £2 in car costs + petrol.
guyblue10 said:
Total annual costs including maintenance, repairs, tyres and depreciation: £8540, or 48.9p per mile
Great info on this thread.
As someone who buys a new R35 every couple of years, I wondered how much more it costs me than keeping the same one for years, obviously 1st and 2nd year depreciation will be the killer, but I'll save on having zero service costs, plus always under warranty.
I try to buy new at almost 10% off retail, so allowing for that and 17.5k miles per year, I reckon 17k over 2 years is about the depreciation figure now, but would have been less 8 years ago when the new cars were in the 50's.
So I reckon buying a new car every 2 years would work out at:
Depeciation: 09/10 14k, 11/12 15k, 13/14 16k, 15/16 17k, total 62k.
Tyres @ 9k intervals: 16 sets, total 16k.
So perhaps something like:
8 years same car : total loss 68k
8 years 4 cars : total loss 78k
On the downside, selling a car privately every 2 years is a hassle, but on the upside getting a new one is exciting. Could also reduce depreciation slightly by buying 6 mnth old cars.
It's why I never have, and never could buy a car new, couldn't stomach the depreciation, even if I were a multi millionaire, I just don't think I could bring myself to do it.
Yep, you have to haggle a good discount and can then get 1st year depreciation down to 10k ish.
Failing that, there's often a good bargain to be had by buying a 6 month old car.
What a brilliant thread, can't believe I've only just seen this. It's great to know these beasts really are the everyday super car. Would have been even more impressed if you kept a tally on fuel costs too :p
Discussion Starter #168
Buying new every 2 years - Interesting alternative. Never thought about that. I'm crap at haggling, hate selling cars and would have to have all R35 Audio's stuff swapped over every time, so I think I'm happy with the route I've taken.
I did about 8k a set on runflats at the beginning, but get much more mileage out of Blizzaks in the winter and MPSS in the summer. Tyreleader seems to be the cheapest over the last few years.
If you want to work out the fuel costs assume 20mpg.....
That is an interesting comparison for sure, I'd highlight that the £22k trade in value is well under what this car is worth, and also highlight that there is £1900 of audio in those numbers which is not like for like and if you took them 6 months ago then there is another £12k engine build which wouldn't be in there.
I think the depreciation is £8k less than stated, and pre build without audio that's another £14k so potentially the numbers might look like 46k vs 78k depending on where you take them (ie immediately after a built engine is exactly the least flattering time for the used car).
Also worth nothing the fewer miles you do the more the costs favour the older car.
My GTR has just passed 100,000 miles last week, all of them driven by me.
While 100k is ***8220;just a number***8221; I thought some of you might be interested in how it***8217;s holding up, how much it***8217;s cost, what***8217;s gone wrong , and what hasn***8217;t.
I bought the car new in June 2009, a base spec in DMG from Middlehursts (non-dimming rear view mirror, non-bose hifi). The basic price was £52,345.60 including mats and reversing sensors.
I had the first few services done by Middlehursts and have used Litchfields since the 4th one. I stuck with 6000 mile service interval until it was 3 years old and then switched to 9000 miles.
The car is pretty much unmodified except I***8217;ve run a generic stage 1 Cobb accessport map from the beginning, I had the later gearbox software installed when it became available and have had Andy***8217;s Audio system fitted. It has the original exhaust.
The interior is holding up well, not creaking signficantly, the seat bolster is holding up well despite my lardy ass.
The exterior is mainly very good ***8211; I had a clear wrap applied to the entire front of the car the day after I picked it up ***8211; there are four areas where the paint is starting to bubble a little: the rear view mirror and around the door handle, both on the driver***8217;s door; the passenger side mirror, and a little bit on the bottom lip of the boot.
Oil consumption has been pretty constant. When I had it serviced every 6000 miles I never needed to add any between services, with the 9000 mile services I need to add a litre between 6-7k miles after a service. This hasn***8217;t changed with the higher mileage.
I bought it to use as my everyday car and use it for most journeys. I***8217;ve never tracked it and never intended to significantly mod it. It does spend a lot of time on motorways, but I do live in the middle of nowhere and the start and end of most long journeys is either 30 or 65 miles of A and B roads to/from the M6 or M42.
What***8217;s gone wrong? The gearbox would only engage 1/3/5 and went into limp home mode (50k miles), a power steering pipe sprung a leak (64k miles), a wheel bearing got very noisy (60k miles), the front speakers decomposed (from about 10 miles), and the multi-function display expired (90k miles, 2 months out of warranty).
The gearbox was cured by the fitting of the piston caps, the power steering pipe was replaced with a ***8220;pipe kit***8221;, the wheel bearing was replaced, the speakers were upgraded and the MFD was replaced with an exchange unit.
The disks and pads lasted 75k miles, and the battery was beginning to show its age after 5 years.
I had the steering lock fixed under warranty, but it wasn***8217;t causing a problem.
I haven***8217;t had any water ingress to the headlights.
The service costs have been:
30 Oct 2009, 5985 miles, Middlehurst, £210.50
1 May 2010, 11696 miles, Middlehurst, £479.19
21 July 2010, 18418 miles, Middlehurst, £905.00
15 Oct 2010, 23740 miles, Litchfield, £327.12
24 Jan 2011, 28817 miles, Litchfield, £149.98
24 Aug 2011, 36279 miles, Litchfield, £764.35
22 Nov 2011, gearbox software upgrade, Litchfield, £300
3 Jan 2012, 42736 miles, Litchfield, £154.79
4 April 2012, 47049 miles, Litchfield, £511.49
18 July 2012, 50942 miles, Middlehurst, Gearbox Piston Cap Kit, £513.32
30 October 2012, 56604 miles (54k service), Litchfield, £485.64
2 July 2012, 64367 miles, Middlehurst, Power Steering hose, £455.12
19 July 2013 65561 miles (60k Service + wheel bearing), Litchfield, £1102.45
19 December 2013, 74812 miles (66k service + F/R disks and pads + replace rear anti roll drop links) £2554.92
June 2014, Speakers replacement (along with Sub, Amp, Processor, Install, R35 audio) £1900
21 June 2014, 84802 miles (72k service + battery), Litchfield, £346.00
August 2014, MFD Display, Middlehurst, £980
1 Dec 2014, 94593 miles (78k service), Litchfield, £512.76
Tyre costs have been:
9 April 2010, Event Tyres, 2x Yokahama, £700.62
16 August 2010, Event Tyres, 4xYokahama, £930
November 2010, Tirerack (USA), 4x Blizzaks, £1350
28 April 2012, Event Tyres, 2x Yokahama, £613.28
3 July 2013 2013, Event Tyres, 2x Yokahama, £481.16
2013, Ebay, 2x GoodYear, £300
October 2014, Tyreleader, 4x Dunlop Winter, £980
So how much has it all cost? ***8211; well, I may have missed a set of tyres along the way, but strictly speaking half of the audio costs weren***8217;t ***8220;necessary***8221;, so I think that evens out.
Total Service costs: £12652
Total Tyre costs: £5355
To work out some interesting numbers we need a valuation, so the current part-ex valuation from the Autotrader site with my reg and mileage is £30,750. Whilst some of you may disagree with this, I intend to keep it for a while longer and will update this post occasionally, so we can use this for comparison purposes in future posts.
So, having done 100,000 miles in 5 years 8 months, an average of 17647 miles/year:
Total service, maintenance and tyre costs: £18007.
Original Cost: £52,345. Current part-ex value: £30,750. Total Depreciation: £21595
Total annual costs including maintenance, repairs, tyres and depreciation: £6988, or 39.6p per mile
Guy
Miss read the start, thats GOOD./
It shows you bought the right car you wanted from the start to keep her all list time, I always fine it funny when people say they've had their car for an long time and it's only been eight months and they are bored already.
That sounds a bit biased Borat, using that sort of reckoning you can make the numbers say whatever you want, we're not in Government you know, ha :)
The tyre expenses could be swapped, the early Gtr could have required a new gearbox, that alone would swing it the other way.
Not to intrude on this thread but I wanted to share another GTR over 100k!
Just picked up a 2009 with 119k (now 120k) on it. This is my first GTR. I have built cars myself for quite awhile (mostly GM and BMW) and am looking forward to joining the GTR realm.
Car seems flawless. As far as I know the previous owner has done a few main maintenance items including:
Timing chain/tensioners
Wheel Bearings
New 2013 Transmission & bellhousing at 56k
Car is modded with around 600hp at the crank. I plan on tracking it so it will be interesting to see how it holds up at this mileage! I am not afraid to tear into it if need be. :cool:
Wheel Bearings
I was going to say you're brave buying something with quite such high mileage, but you probably got a bargain and if you're a real grease monkey you could have some real fun Modding it further.
Also, since you're tracking its probably better to buy one with miles than beast a garage queen.
Good luck with car and welcome!
Sent from my SM-G930F using Tapatalk
Definitely a bit of a gamble but we'll see how it turns out! As long as I don't shoot a rod out of the block I'll be fine with fixing anything that happens :chuckle:
I don't think you'll have any major issue's, they seem to be very well engineered as all jap stuff tends to be.
My worse experience has been with vw, had 1 car and that was enough.
