R32 GTR Parts
R32 GTR O/S front wing creased £195
R32 GTR footwell trim cover o/s with flare holder £60
R32 GTR centre console (arm rest) £35
R32 GTR Lower steering column £49
R32 GTR Lower dash trims without vents £45
R32 GTR Ashtray £129.99
R32 GTR lower dash trims, modified £15
R32 GTR lower column trim £30
R32 GTR door coin pocket £35
R32 GTR door handle lever surround (not sided) £15
R32 GTR O/S door glass weather seal £120
R32 GTR n/s boot corner carpet £60
R32 GTR boot carpet panels o/s £60
R32 GTR Dash board, perfect condition, with all vents £995
R32 GTR Dashboard bare, no blisters £395
R32 GTR right upper de mist vent, as new £89
R32 GTR fuse box cover £50
R32 GTR passenger side pillar trims £30
R32 GTR interior sill trims £35, right side only
R32 GTR drivers side pillar cover £30
R32 GTR lower centre console £45
R32 GTR n/s/f hub good bearing £159
R32 GTR o/s/f hub good bearing £159
R32 GTR o/s/f hub complete £159
R32 GTR n/s/f hub with shield £159
R32 GTR o/s/r hub £159
R32 GTR n/s/r hub £159
R32 GTR front suspension uprights freshly powder coated black £149.99 each
R32 GTR rear upper control arms, blasted painted and poly bushed £69.99 each
R32 GTR o/s outer door trims £65
R32 GTR rear bench top half £100
R32 GTR undertray £40
R32 GTR atessa and hicas pump £275
R32 GTR power steering brackets £50
R32 GTR air con pump brackets £25
R32 GTR speedo cluster £195
R32 GTR Light cover N/S £65
R32 GTR Light unit O/S £74
R32 GTR Passenger wind deflector £95
R32 GTR Door cards £50 with no trim
R32 GTR Inner rear quarter cards £50 no trim
R32 GTR Full mat set £135
R32 GTR Hicas control valve £49.99
R32 GTR Wiper switch £69.99
R32 Automatic transmission ecu £49.99
R32 GTR Viscous coupling fan £74.99
R32 GTR Brake master cylinder £79.99
R32 GTR SPACE SAVER Spare wheel £120
R32 GTR Heated rear screen switch £49
R32 GTR Mirror switch £14.99
R32 GTR Door handles (outer) £24.99 each
R32 GTR HICAS ecu £199
R32 GTR Gearbox cross member £95
R32 GTR Undertray front £40
R32 GTR Metal door guide trims £290 for pair
R32 GTR Ashtray smooth black £125
R32 GTR Exterior body trims £165 each side or £320 for a pair
R32 GTR C PILLAR TRIMS £80 PER SIDE
R32 GTR Rear subframe fresh powder coated £250 exchange
R32 GTR Hicas lock out bar £40
R32 GTR Roof skin (full roof cut) £495
R32 GTR black Nismo gear knob £89
R32 GTR engine damper and bracket £49 (unbranded)
R32 GTR Gearbox harness £160
R32 GTR GTST reverse lights L+R £100 each
R32 GTR saurus low level drag spoiler £495 (mounting stud needs repair, easy fix)
R32 GTR carbon lower boot spoiler N1 copy £100 (minor repair need to seam)
R32 GTR nistune modded ecu £395
R32 GTR OEM side skirts (no end caps) £199 each
R32 GTR OEM battery cover £65
Genuine Nissan R32 GTR Front and rear set of window seals with moulding £503.96 + vat
Genuine Nissan NEW R32 GTR door handle surrounds £39
Genuine Nissan NEW R32 GTR door handles left and right £49 each
Genuine Nissan NEW R32 GTR Door window seals L+R £149 each
R33 GTR Parts
R33 GTR o/s rear interior quarter panels £50
R33 GTR airbag ecu £45
R33 GTR sill trims £30 pair
R33 GTR steering column cover trims £45
R33 GTR centre console £65
R33 GTR rear exterior panel (below boot lid) skyline embossed £45
R33 GTR rear view mirrors £45
R33 GTR o/s footwell trim plastic £45
R33 GTR n/s footwell trim plastic £45
R33 GTR radiator trim cover £75
R33 GTR dash facia £65
R33 GTR side skirts £280 full with cap 1 set remaining
R33 GTR dash clocks £10
R33 GTR hazards switches £10
R33 GTR wing mirror switches £12
R33 GTR boot side carpet no hatch for atessa £25
R33 GTR boot side carpet GTS £25
R33 GTR rear boot panel £65
R33 GTR fuse box cover £55
R33 GTR sun visors £35 each
R33 GTR Headliner £250
R33 GTR b-c pillar interior trim n/s £20
R33 GTR b-c pillar interior trim o/s £20
R33 GTR o/s door glass £50
R33 GTR n/s door glass £50
R33 GTR o/s strut top panel £99
R33 GTR pair rear shocks oem with lowering springs £60
R33 GTR O/S/F hub £60
R33 GTR n/s/f hub £60
R33 GTR n/s/f hub carrier only £60
R33 GTR o/s/r hub £60
R33 GTR n/s/r hub £60
R33 GTR boot lid (bonded shut) £50
R33 GTR aircon pump £69
R33 GTR Rear screen £200 collection only
R33 GTR front windscreens £150 collection only
R33 GTR abs control unit £69
R33 GTR power steering reservoir £30
R33 GTST Coupe set of 4 Coil springs £65
R33 GTR Aircon pump £95
R33 GTR Coilpack harness £99
R33 GTR GTST front wiper motor £39
R33 GTR floor mats £140
R33 GTST GTR Heater control £65
R33 GTR Starter motor £69
R33 GTR Rear lower A arm £85.99 each
R33 GTR Centre cluster £79.99
R33 GTR Boot catch mechanism £49
R33 GTR Spec 2 airbag £69
R33 GTR Speedo trim surround £29
R33 GTR Atessa ecu £189
R33 GTR GTST Centre heater vent £15
R33 GTR HICAS ECU £189.99
R33 GTR AIRBAG ECU £89.99
R33 GTR GTST Heated window and hazard switch £19
R33 GTR Wiper stalk £19
R33 GTR GTST DASH COIN pockets £9.99
R33 GTR GTST RH Heater vent £9.99
R33 GTR Mirror switch £12.99
R33 GTR Brake servo wiring harness bracket £19.99
R33 GTR Fuel flap release cap £9.99
R33 GTR Front under tray £40
R33 GTR ROOF Skin £295
R33 GTR spec 2 airbag dashboard £495
R33 GTR Carbon N1 style bonnet spoiler £70 (x2 stone chips)
Genuine Nissan R33 GTR Front and rear set of window trims £375+vat
Genuine Nissan R33 GTR front bumper skin £594 without n1 vents
Genuine Nissan R33 GTR Front splash guard RHS £100
Genuine Nissan R33 GTR Front splash guard LHS £100
Genuine R33 GTR Rear quarter panels LHS £595+vat
Genuine R33 GTR Rear quarter panels RHS £595+vat
Genuine R33 GTR Front window seal kit and moulding £174.71 + vat
Genuine R33 GTR Rear window seal kit and moulding £175.78 + vat
Genuine R33 GTR Vspec rear decal £10.75 + vat
Genuine R33 GTR Rear boot emblem £48.99+vat
Genuine R33 GTR Front emblem £36.34+vat
Genuine R33 GTR Boot floor £560.39 + vat
Reproduction Leman quarter decals £7.95
R34 GTR Parts
R34 GTR front o/s wing, minor damage £395 x2
R34 GTR o/s lower footwell cover, no door £49
R34 GTR n/s lower footwell cover, no door £49
R34 GTR n/s dash footwell panel £49
R34 GTR Lower centre console £65
R34 GTR Glove box lid £49
R34 GTR Dash board £249
R34 GTR Bonnet release cable £65
R34 GTR Bonnet release mechanism £79
R34 GTR Lower steering cowl £55
R34 GTR nsf hub £169
R34 GTR o/s/f hub carrier only £90
R34 GTR o/s/r hub £169
R34 GTR n/s/r hub £169
R34 GTR ABS Control unit £165
R34 GTR passenger SRS airbag module £70
R34 GTR Skyline footrest £25
R34 GTR Heater blow £200
R34 GTR Lower dash £85
R34 GTR Front wiper motor £55
R34 GTR passenger window switch £29
R34 GTR Centre console lower £35
R34 GTR RH lower dash trim mspec £65
R34 GTR PASSENGER DOOR PULL HANDLE TRIM £55
R33 GTR SPEEDO SURROUND TRIM 68240-15U00 £55
R34 GTR FUEL FILLER NECK WITH CAP £149
R34 GTR MSPEC NUR rear anti roll bar £195
R34 GTR Front adjustable tie rod end £85
R34 GTR Atessa ecu £289
R34 GTT HICAS ECU £149
R34 GTT NISMO REAR BUMPER £199
R34 GTR Rear quarter glass LHS £140
R34 GTR Rear quarter glass RHS £140
R34 GTR body wiring harness with fuse box £1800+vat
R34 GTR spoiler blade.
Genuine Nissan R34 GTR Rear quarter panel LHS £595+ vat
Genuine Nissan R34 GTR Rear quarter panel RHS £595+ vat
Genuine Nissan R34 GTR Front splash guard lower RHS £155.75+ vat
Genuine Nissan R34 GTR Front splash guard lower LHS £155.75+ vat
Genuine Nissan R34 GTR Front slash guard upper RHS £126.68 + vat
Genuine Nissan R34 GTR Front splash guard upper LHS £126.68 + vat
Genuine Nissan R34 GTR Vspec undertray diffuser £775.63+vat
Genuine Nissan R34 GTR Front window moulding £78.93 +vat
Genuine Nissan R34 GTR Rear window moulding £76.68+vat
RB26 parts
RB26 plenum manifold £120
Rb26 NEW long nose crank £1026.95
RB26 Steel internal turbos £895 + Exchange
RB26 Injector harness
RB26 Engine bay power loom
RB26 Ignition module
RB26 POLISHED TIMING BELT COVER £160
RB26 pcm valve £55
RB26 starter motors £100
RB26 flywheels r32/33 £40
RB26 std pistons and rods £45
RB26 CAM ANGLE SENSOR £165
RB26 STD FUEL RAIL £30
RB26 STD FUEL RAIL re finished £59.99
RB26 Rear intake elbow £15
Rb26 front turbo intake pipe £15
RB26 Refinished turbo and water pipes from £29.99 each
RB26 BLITZ SUS POWER INDUCTION KIT £160
RB26 HKS MUSHROOM INDUCTION KIT £180
SPARCO HARNESS SET £99
RB26 USED OIL PUMPS £29
Rb26 R32/33 GTR airflow meters £69 each
RB26 N1 GENUINE NISSAN OIL PUMP £245 BNIB
RB26 CRANKSHAFT GENUINE NEW £893
Mines RB26 Rocker baffle kit £295
Tomei fuel rail in blue £249.99
Tomei Expeme TI decat pipe £199
GTR HC baffled twin turbo charge pipe £169 exchange (100 surcharge
RB25DET green label airflow meter
Apexi muiltchecker (period dash instrument ) £199
R35 GTR PARTS
R35 GTR Rear spec – v Nismo carbon fibre rear diffuser £2500
R35 GTR Top A pillar trims in grey £195 per side
R35 GTR CBA Rear tail lights £175 each
R35 GTR front grille £69
R35 GTR TOP ENGINE COVER £99
R35 GTR Carbon grille cover £139 (DW)
R35 CBA NATTACK CLUBSPORT REAR Carbon diffuser tray £2500
