1 - 12 of 12 Posts
1000’S OF USED AND NEW PARTS AVAILABLE this is a smidge of what we currently have in stock
R32 GTR Parts
R32 GTR N/S front wing £350
R32 GTR N/S front wing creased £195
R32 GTR footwell trim cover o/s with flare holder £60
R32 GTR centre console (arm rest) £25
R32 GTR Steering column cover top and bottom £55
R32 GTR Lower steering column £29
R32 GTR Lower dash trims without vents £25
R32 GTR Ashtray £90
R32 GTR lower dash trims, modified £15
R32 GTR lower column trim £30
R32 GTR handbrake lever and with working ratchet £65
R32 GTR lower centre console, with rare oem knee support pad £295
R32 GTR door coin pocket £15
R32 GTR door handle lever surround (not sided) £15
R32 GTR n/s boot corner carpet £60
R32 GTR firewall panels £25
R32 GTR boot carpet panels o/s £60
R32 GTR dash board has vinyl crack £160
R32 GTR fuse box cover £50
R32 GTR passenger side pillar trims £30
R32 GTR interior sill trims £65 pair
R32 GTR drivers side pillar cover £30
R32 GTR full boot shut trim panel £40
R32 GTR lower centre console £25
R32 GTR n/s/f hub good bearing £159
R32 GTR o/s/f hub good bearing £159
R32 GTR o/s/f hub complete £159
R32 GTR n/s/f hub with shield £159
R32 GTR o/s/r hub £159
R32 GTR n/s/r hub £159
R32 GTR o/s outer door trims £65
R32 GTR rear bench top half £100
R32 GTR pair rear brake calliper’s £120
R32 GTR o/s front callipers £75
R32 GTR scuttle panels £70
R32 GTR undertray £40
R32 GTR kyb shocks and springs set coil overs £50
R32 GTR atessa and hicas pump £275
R32 GTR frp front cooling panel £20
R32 GTR power steering brackets £50
R32 GTR air con pump brackets £25
R32 GTR speedo cluster £195
R32 GTR rear wiper motor £59.99
R32 GTR Iac valve £45
R32 GTR orange rear strut brace £245
R32 GTR centre dash 3 gauge cluster £99
R32 GTR Light cover N/S £35
R32 GTR Light unit O/S £74
R32 GTR RADIATOR SHROUD NO MODS OR CRACKS £70
R32 GTR Passenger wind deflector £95
R32 GTR Door cards £50 with no trim
R32 GTR Inner rear quarter cards £50 no trim
R32 GTR Drivers side front wing £350
R32 GTR Full mat set £135
R32 GTR AIR CON PUMP X 2 STOCK £125
R32 GTR Hicas control valve £49.99
R32 GTR Power steering pump £295
R32 GTR Full front arch lines £350 pair
R32 GTR Wiper switch £69.99
R32 Automatic transmission ecu £49.99
R32 GTR Viscous coupling fan £74.99
R32 GTR VEILSIDE STEP 2 ECU TUNED £129
R32 GTR Brake master cylinder £79.99
R32 GTR SPACE SAVER Spare wheel £120
R32 GTR Heated rear screen switch £49
R32 GTR Mirror switch £14.99
R32 GTR driver’s door window switch £14.99
R32 GTR DOOR HANDLE SURROUND £12.99
R32 GTR Door handles £8.99 each
R32 GTR HICAS ecu £199
R32 GTR Gearbox cross member £95
R32 GTR Undertray front £40
R32 GTR Boot carpet £50
R32 GTR Metal door guide trims £290 for pair
Genuine Nissan R32 GTR Front and rear set of window seals with moulding £503.96 + vat
R33 GTR Parts
R33 GTR o/s rear interior quarter panels £50
R33 GTR airbag ecu £45
R33 GTR sill trims £30 pair
R33 GTR steering column cover trims £25
R33 GTR centre console £25
R33 GTR rear exterior panel (below boot lid) skyline embossed £25
R33 GTR rear view mirrors £25
R33 GTR o/s footwell trim plastic £18
R33 GTR n/s footwell trim plastic £18
R33 GTR radiator trim cover £55
R33 GTR dash facia £55
R33 GTR side skirts £280 full with caps
R33 GTR series 2 dash board £79
R33 GTR dash clocks £10
R33 GTR hazards switches £10
R33 GTR wing mirror switches £12
R33 GTR boot side carpet no hatch for atessa £30
R33 GTR boot side carpet GTS £25
R33 GTR rear boot panel £29
R33 GTR atessa pump shield £20
R33 GTR fuse box cover £30
R33 GTR sun visors £20 each
R33 GTR Headliner £100
R33 GTR b-c pillar interior trim n/s £20
R33 GTR b-c pillar interior trim o/s £20
R33 GTR boot lid carpet £40
R33 GTR o/s quarter glass £99
R33 GTR o/s door glass £50
R33 GTR n/s door glass £50
R33 GTR o/s strut top panel £99
R33 GTR pair rear shocks oem with lowering springs £60
R33 GTR front strut braces £50
R33 GTR rear strut braces £50
R33 GTR O/S/F hub £60
R33 GTR n/s/f hub £60
R33 GTR n/s/f hub carrier only £60
R33 GTR o/s/r hub £60
R33 GTR n/s/r hub £60
R33 GTR boot lid (bonded shut) £50
R33 GTR aircon pump £69
R33 GTR Rear screen £200
R33 GTR front windscreens £150
R33 GTR abs control unit £69
R33 GTR non v spec attessa pump £189
R33 GTR power steering reservoir £30
R33 GTR v spec style rear spats £55
R33 GTR Brembo front callipers £695
R33 GTR Brembo rear callipers £395
R33 GTST Front indicators £40
R33 GTST rear spoiler rubber gaskets
R33 GTST Coupe set of 4 Coil springs £65
R33 GTR Rear boot panel £29
R33 GTR rear arch spats £49
R33 GTR Aircon pump £95
R33 GTR Coilpack harness £99
R33 GTR BONNET HINGES PAIR £80
R33 GTR GTST front wiper motor £39
R33 GTR B pillar trims spares carbon wrapped £10
R33 GTR Spoiler blade £100
R33 GTR MATS £145
R33 GTST GTR Heater control £65
R33 GTR Starter motor £69
R33 GTR Radiator and shroud £99
R33 GTR Rear lower A arm £85.99 each
R33 GTR Centre cluster £79.99
R33 GTR Boot catch mechanism £49
R33 GTR Spec 2 airbag £69
R33 GTR Speedo trim surround £29
R33 GTR Atessa ecu £189
R33 GTR GTST Centre heater vent £15
R33 GTR HICAS ECU £189.99
R33 GTR AIRBAG ECU £89.99
R33 GTR GTST Heated window and hazard switch £19
R33 GTR Wiper stalk £19
R33 GTR GTST DASH COIN pockets £9.99
R33 GTR GTST RH Heater vent £9.99
R33 GTR Mirror switch £12.99
R33 GTR Brake servo wiring harness bracket £19.99
R33 GTR Fuel flap release cap £9.99
R33 GTR NON VSPEC Rear drive shafts £190 each
R33 GTR Front under tray £40
Genuine Nissan R33 GTR Front and rear set of window trims £375+vat
Genuine Nissan R33 GTR front bumper skin £445.16
Genuine Nissan R33 GTR series 3 front splitter £493.14
Genuine Nissan R33 GTR Front splash guard RHS £70
Genuine Nissan R33 GTR Front splash guard LHS £70
Genuine R33 GTR Rear quarter panels LHS £550+vat
Genuine R33 GTR Rear quarter panels RHS £550+vat
Genuine R33 GTR Front window seal kit and moulding £161.71 + vat
Genuine R33 GTR Rear window seal kit and moulding £159.78 + vat
Genuine R33 GTR Vspec rear decal £10.75 + vat
Genuine R33 GTR Rear boot emblem £43.99+vat
Genuine R33 GTR Front emblem £36.34+vat
Genuine R33 GTR Boot floor £402.39 + vat
R34 GTR Parts
R34 GTR o/s lower footwell cover, no door £49
R34 GTR n/s lower footwell cover, no door £49
R34 GTR n/s dash footwell panel £49
R34 GTR Lower centre console £65
R34 GTR Glove box lid £49
R34 GTR Dash board £249
R34 GTR Bonnet release cable £65
R34 GTR Bonnet release mechanism £79
R34 GTR Lower steering cowl £55
R34 GTR nsf hub £169
R34 GTR o/s/f hub carrier only £90
R34 GTR o/s/r hub £169
R34 GTR n/s/r hub £169
R34 GTR n/s driveshaft £250
R34 GTR o/s driveshaft £250
R34 GTR aircon pump £169
R34 GTR ABS Control unit £165
R34 GTR passenger SRS airbag module £70
R34 GTR Kakimoto exhaust system cat back 2 silencer (test fit only) £395
R34 GTR Reverse light £50
R34 GTR Skyline footrest £25
R34 GTR atessa bottle and pipes £80
R34 GTR Heater blow £200
R34 GTR Lower dash £85
R34 GTR Rear 3rd level £40
R34 GTR Front wiper motor £55
R34 GTR passenger window switch £29
R34 GTR Centre console lower £35
R34 GTR RH lower dash trim mspec £65
R34 GTR STOCK FUEL PUMP £50
R34 GTR HANDBRAKE AND CABLE MECHANICSM £65
R34 GTR PASSENGER DOOR PULL HANDLE TRIM £55
R34 GTR INDICATOR STALK £29
R34 GTR INTERIOR LIGHT £25
R34 GTR WINDSCREEN WIPER STALK £29
R34 GTR STEERING WHEEL BACK PLATE £29
R33 GTR SPEEDO SURROUND TRIM 68240-15U00 £55
R34 GTR FUEL FILLER NECK WITH CAP £55
R34 GTR REAR LOW DRAG SPOILER LEGS £195
R34 GTR CARBON SILL PLATES £99
R34 GTR APEXI POWER FC ECU WITH HAND CONTROLLER £549
R34 GTR HKS SUPER DRAGGER EXHAUST £295
R34 GTR FRONT LOWER SPLITTER £395
R34 GTR STANDARD CLUTCH AND DUAL MASS FLYWHEEL £345
R34 GTR FRONT SPLITTER LOWER £395
R34 GTR SPOILER BLADE £395
R34 GTR MSPEC NUR rear anti roll bar £195
R34 GTR Front adjustable tie rod end £85
R34 GTR AIR CON PUMPS £149
R34 GTR Rear bottom A arms with poly bushes £180
R34 GTR BRAKE MASTER SERVO £149
R34 GTR Atessa ecu £289
R34 GTR VSPEC REAR DRIVE SHAFTS £249 each
R34 GTT HICAS ECU £149
R34 GTT NISMO REAR BUMPER £199
R34 GTR Rear quarter glass LHS £140
R34 GTR Rear quarter glass RHS £140
Genuine Nissan R34 GTR Rear quarter panel LHS £556.63+ vat
Genuine Nissan R34 GTR Rear quarter panel RHS £556.63+ vat
Genuine Nissan R34 GTR Front splash guard lower RHS £155.75+ vat
Genuine Nissan R34 GTR Front splash guard lower LHS £155.75+ vat
Genuine Nissan R34 GTR Front slash guard upper RHS £126.68 + vat
Genuine Nissan R34 GTR Front splash guard upper LHS £126.68 + vat
Genuine Nissan R34 GTR Vspec undertray diffuser £775.63+vat
Genuine Nissan R34 GTR Front window moulding £78.93 +vat
Genuine Nissan R34 GTR Rear window moulding £76.68+vat
RB26 Parts
RB26 plenum manifold £80
RB26 Steel internal turbos £895 + Exchange
RB26 Injector harness
RB26 Engine bay power loom
RB26 Ignition module
RB26 POLISHED twin turbo pipe with badge £150
RB26 POLISHED TIMING BELT COVER £160
RB26 aac valves £55
RB26 pcm valve £55
RB26 front diffs sumps £280
RB26 starter motors £100
RB26 flywheels r32/33 £40
RB26 std pistons and rods £45
RB26 TIMING CAM BACK PLATE £70
RB26 TIMING COVER IN RED £100
RB26 CAM ANGLE SENSOR £165
RB26 STD FUEL RAIL £20
RB26 Rear intake elbow £15
Rb26 front turbo intake pipe £15
RB26 Cam angle sensor £ 159.99
RB26 BLITZ SUS POWER INDUCTION KIT £160
RB26 HKS MUSHROOM INDUCTION KIT £180
RB26 BAFFLE TWIN TURBO PIPE
SPARCO HARNESS SET £99
RB26 USED OIL PUMPS £29
RB26 N1 GENUINE NISSAN OIL PUMP £245 BNIB
R35 GTR PARTS
Stainless non-resonated ypipe £295
R35 GTR Top A pillar trims in grey £195 per side
R35 GTR CBA Rear tail lights £175 each
R35 GTR front grille £69
R35 GTR TOP ENGINE COVER £99
Hi Dave, do you have a set of front diff mounting bolts and a full set of driveshaft bolts (x12) for a non vspec r33 gtr? Thanks
R34 GTR Parts
Hi Davew,
I saw the huge list of R34 GTR parts. I wonder if the parts came from a crashed car? I am looking for a R34 GTR in bad condition or crashed with V5, do you have the shell ?
Best regards
hi looking for a clutch for a r33 gtr i should be running about 650 bhp dont know if i should be going for twin or triple plate do you have anything with good plates and how much thanks
Hi, I'm after the connector from the front turbo on a R32 GTR
From the twin turbo pipe, to the front turbo, the small connector
261657
Hi,
Would you have the following for an r33 gtr:
1. OEM Intake
2 OEM Oil Cap (cap on valve cover to fill oil)
3. OEM Radiator Cap
4. OEM ECU
5. OEM Intercooler Piping
1 - 12 of 12 Posts
