1 - 17 of 17 Posts
trundling along the motorway tonight i decided to see what the accelleration was like in 5th so i floored it.
it was great 80 90 100 110 115 and then nothing iwas at 5 thousand revs and the car just would not go anymore
does anyone know why this might be i mean my bloody mondeo can do more than that:( :(
Administrator
hahaha
sounds like its still restricted dude, all japanses cars were limited to 110ish mph
look up deristricting for the r32 gtr
good luck
mook
I thought the speed restriction on the R32 was only if it was still in KMH?
I was having that problem when i first got mine, it hit 180 KMH and that was it, but when i changed it into MPH it sailed past 112 mph.
Discussion Starter #6
mine still is in kph i have one of those cam detectors and it shows me the mph speed iam doing digital, anyway what a bugger i was told by the guy i bought it off that it was deristricted. ok does anyone know how???:)
Yes, i bought a worm gear type restrictor, unplug speedo cable from gearbox, plug the converter in its place, screw cable into converter..
Some people say it causes problems with the HICAS, but as i never push my cars handling to the limit, ive noticed no difference at all.
Got it from here >>>>
KM3 speedo converter and delimiter
I seem to remember someone telling me there is a wire on the ECU loom that you snip to remove the speed limit? This way it stays in KMH so as not to upset the HICAS reaction times.
do not cut the wire on the ECU, this will totally screw up the hicas as it won't see any speed signal.
there was a post a few days ago detailing how to do this iirc. Cut a wire somewhere that interrupts the VSS in a way that allows the HICAS to see a signal but not whatever does the limiting.
if you convert it to mph then the limt will be 180mph, which is close enough to un-restricted as most people need.
If you get an aftermarket ECU then you won't have any problems.
1 - 17 of 17 Posts
