Status
Not open for further replies.
1 - 20 of 41 Posts
Heya Peeps,
Finally made up my mind as to what i'm going to do with the car,
As much as i would love to keep this engine and be able to say i'm able to drive it to it's full potential...i can't...i don't mind admitting it either lol...So i'm building up another engine to drop in...something a little bit different but time will tell.
So here is the spec.
1200BHP HKS 2.8L Bottomend Full Counter weight crank,
H section rods 22mm Gudgen Pin,
86.5mm Special coated pistons, Balanced.
Early R32 Block.
Nismo Bearings main & bigends.
HKS ATI crank damper kit.
TOMEI Main studs.
TOMEI Oil pump.
Nismo baffled GTR sump modified to fit GTST.
TOMEI 1.2mm headgasket kit.
TOMEI Head studs + washers.
TOMEI Cam studs.
TOMEI Type B springs.
TOMEI Spring retainers.
TOMEI Valve buckets.
TOMEI Bronze Valve guides.
TOMEI Shims.
TOMEI 280 Deg 11.5mm IN/EX.
TOMEI Timing belt.
HKS Durallium cam sprockets.
NISMO Oil cap.
NISMO Thermostat.
Sard 800cc injectors.
GReddy 11mm fuel rail.
Trust/GReddy inlet manifold.
HKS T04Z top mount turbo kit with HKS GT 2 wastegate.
Splitfire coil packs.
Custom Full Drag spec head matched IN + EX.
Nismo silver top twin plate clutch + flywheel with brand new friction plates.
Mines rocker cover baffle plates.
Apexi power fc d-jetro with commander, sensors and boost controller.
So basically in a nut shell, this engine is coming complete with engine wiring loom, ecu all mapped ready to go, coolant hoses (except radiator and heater matrix), all you need is a fmic and pipes, breather hoses and fuel lines/pumps...
The engine has done a grand total of about 2500 miles since being built,most of which have been dyno,
At present she is running near 750bhp at the flywheel, i have a dyno sheet to prove it,
Looking for £14,750 for the lot,
See pics below.
Sorry if i have missled people....the fact stands that the engine is capable of 1200bhp...the tittle states....1200bhp gtr engine....which it is....
Yes it is running 750bhp at present, this is only due to the size of the turbo and injectors used...i believe in reliable power...
The engine alone would cost the price i'm asking to be built....so to a certain degree you are getting a complete engine with the added bonus of all manifolds and ancilleries...
I hope this has helped clear that up...
As to all the genuine interest i've had...many thanks.
Cal
Cal
I must agree,you are missleading with this advert.
But its still a very impressive engine,so best of luck with the sale.:)
Discussion Starter · #10 ·
Price now £13,750 to sell...
I am willing to break this setup apart....but the block/head have to go complete first before i sell anything else.
Many thanks..
Cal
Discussion Starter · #12 ·
Offers anyone?, this is a truly awesome engine,
I will take px, preferably a small block chevy engine but anything considered...
Many thanks
Cal
Free bump
I know this car and the company that built it, it is a very nice motor indeed and built to an extremley high spec and standard.
The reason for sale i believe is to put a dirty V8 in it lol :thumbsup:
best of luck with the sale and your new project:thumbsup:
Discussion Starter · #15 ·
Offers People????
Price now £12,999.....a major bargain.....
Just a quick update to answer a few questions,
The sump is a modified GTR sump to suit the GTsT subframe,
It's only the engine that has covered 2500 miles, the turbo kit,coil packs, injectors etc have only covered 1500 miles of that amount, I bought the engine with 1000 miles on it.
Hope this helps.
Cal
absolute bargin!!!!:flame::flame::flame:
you paid that much just to buy the complete long engine from me!!!!:eek:
cal your mad:chairshot:thumbsup:
Discussion Starter · #18 ·
Thanks for the comment Matt :)
I know i'm mad lol, i just get bored easily and need new projects all the time, that and this thing is scary as hell haha.
As to all the questions regarding parts off of this engine, i will split and sell but only if the engine on it's own sells first.
Many thanks.
Cal
1 - 20 of 41 Posts
Status
