We are offering a whopping 15% off all GTR Whiteline products.
The prices below are RRP, we can offer all GTR members 15% off this!
+ Postage or Fitting
KCA402
Front Control arm - lower inner rear bushing (anti-lift/caster correction)
A WALK or Whiteline Anti Lift Kit fitted to your vehicle will result in more complaint suspension during braking and acceleration reduced understeer with increased front end grip and sharper more prec... <read more>
Adds +0.1º caster + anti-lift
GBP 215.98inc tax
KCA403
Front Control arm - upper inner bushing (camber correction)
Adds +/- 0.5º camber
GBP 150.00inc tax
KLC172
Front Sway bar - link assembly
Performance sway bar links utilising a heavy duty steel ball joint ends that adjust & rotate to any angular combination. Eliminate sway bar preload via the light weight aluminium bodies provide 15... <read more>
Adjustable extra heavy duty
GBP 109.00inc tax
KLC173
Rear Sway bar - link assembly
Performance sway bar links utilising a heavy duty steel ball joint ends that adjust & rotate to any angular combination. Eliminate sway bar preload via the light weight aluminium bodies provide 25... <read more>
GBP 109.00inc tax
BNF40Z
Front Sway bar - 33mm heavy duty blade adjustable
This Whiteline 33mm 2 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline... <read more>
2 point adjustable
GBP 325.14inc tax
BNR36XZ
Rear Sway bar - 20mm X heavy duty blade adjustable
This Whiteline 20mm 3 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline... <read more>
3 point adjustable
GBP 177.47inc tax
KCA402
GBP 215.98inc tax
KCA403
GBP 150.00inc tax
KLC172
GBP 109.00inc tax
KLC173
GBP 109.00inc tax
BNF40Z
2 point adjustable
GBP 325.14inc tax
BNR36XZ
3 point adjustable
GBP 177.47inc tax
