Not quite. Having been educating myself recently on competition braking systems there are a few other issues, two being rotational mass and rotational inertia. BIG rotors at high speeds act in a similar way to gyroscopes and increase the force required to turn the steering wheel away from straight-ahead.
You can go for smaller, yet wider rotors which keep the same thermal mass for good heat dissipation. Most folks want dustbin lid sized rotors for thr racecar look but fail to grasp that MASSIVE is not necessarily the way to go.
TT
I put both of the above under weight myself but there you go. I was going to put a comment about the gyroscopic effects of big discs.
Not sure a small thick disc would help with heat dissipation. It would certainly have a higher thermal capacity but without a corresponding increase in surface area you could have issues with thermal inertia. I've seen a couple of superbike projects where people have replaced the forks with single swinging arms (rather than double arms as per Bimota/Vyrus et al). They tended to go with a single disc set-up but massively thick (for a bike). From what I read they tended to be great until the disc got hot then you'd have nothing until you parked up and let it cool down.
On this front I find it interesting that the Sumitomo and Brembo set-ups use fairly similar callipers but the Brembo set-up uses thinner bigger discs to the Sumitomo. Of course this may just be because that's the size the Brembos came in but I slightly discount this on the basis that the Z32 TT has the same type of Sumitomo callipers but running a smaller thinner disc. I suppose it depends how much stuff is specified by the designer and how much it just buying stuff 'off the shelf'.
Ummm I'm sure I had a point somewhere...:thumbsup:
