Im sad to say that its time for the skyline to go
with buying a new bigger house and having three vehicles (of which none do over 30MPG) the costs are adding up.
I have had the car for approx 18 months and its been a joy from day one.
heres a brief spec of the car and the work which has been carried out, people who have seen the car will vouch for the mechanical soundness of it.
Engine Spec
HKS Air Filters (new filters)
HKS Down pipes
Blitz Turbo Timer
Blitz SSQV dump Valves
Blitz Type R Boost Controller
Blitz Nur Spec Exhaust (with bung)
Decat
Apexi Hybrid Front Mount
D1 Spec Catch Can
Carbon Fibre Cam Pulley Cover
Ally Air cooling panel
Suspension/Wheels
17" OZ 3 Piece Split Rims with Toyo T1R Rubber
Front and Rear upper Braces
Tein Springs
Brakes
Brembo 4 pots on front
New EBC Drilled & Grooved Discs
Red stuff pads on front, Red stuff pads for rear (to be fitted)
Others
Silk Road Headlight Vent (stock available)
Ganador Style mirrors (stocks available
Trust style Rear Spats (to be fitted)
New Gear & Handbrake Gaitor
Ally Gearknob
Razo Pedals
Alloy Oil Cap
New injector Seals
recent battery
The mechanics of the car are in very good condition, I have completed approx
14k miles in the car and it hasnt let me down once, the engine burns no oil or water. and starts every time.
The car is running 1.0 bar of boost (well just under) and should be between 360-380BHP i am told
oil changes have been done at every 6k miles since i have owned it, including plugs and fuel filters
The bodwork is 99% rust free, however the laquer has started coming off in places, the roof being the worst. and has a few little nics here and there
as you can see by the pictures the car still cleans up really nicely, but would need a few bits of paint for it to be mint
The only other problems with the car are that the heater is stuck on HOT a lot of the time, the central locking doesn't work on the passenger side, the boot lock only opens from the boot pull and not the key. and the starter squeels a little when starting (have been told the shaft needs greasing but have been unable to do this)
any questions please call me on 07877 853201
£6500
Engine Spec
HKS Down pipes
Blitz Turbo Timer
Decat
D1 Spec Catch Can
Suspension/Wheels
Tein Springs
Brakes
Others
Ally Gearknob
Razo Pedals
Alloy Oil Cap
New injector Seals
recent battery
£6500
