right i have an eclipse blade autococker with a ton of gear thats all new and un used.
The marker itsself has only shot about 500 balls while i was setting it up but thats it! the 2 air systems have only had one fill and the other 2 fills! and the rest is unused.
what is included is:
*The marker which i have upgraded with a evo magnum44 ram and eclipse QEV's and has a smartparts drop forward and on/off valve.
*Viewloader EvolutionII hopper with the upgraded Z board fitted (also come with standard board) and an uprated loader paddle.
*A few spares including lots of low pressure hose and the old ram and anti double ball detants.
*3 bags of re balls.
*Hitman derlin bolt.
*2 1.1L pro toyz 5000 psi air systems.
* one invent bottle cover.
*2 14 inch barrels 1 is a REDZ pepper stick.
*2 swabs 1 fluffy stick and 1 pull through.
* Empire E Vent goggles with custom ear flaps from L.I.P.S with spare clear lense and sun peak.
* Eclipse Etek pants in size small with swab and shot pot holders on the back and build in padding.
* Jacko 3 pot battle pack i na small to medium waist size
*5 140 shot pots 3 blue 2 clear.
*smartparts slide short in small.
*2 barrel condoms 1 smartparts and 1 eclipse.
* skull paintball neck gaurd.
*3 bandanas 2 with head and neck mesh.
* Kamikaze marker stand.
And thats about it for now!
Right the importand part!!!
What i want to swap for is an upgraded turbo and injectors for my rb20det or for a turbo kit and manifold along the lines of a trust td06. a long shot but worth a go.
Pic time
Pic time
