I've owned this Auto Nissan Navara Outlawn from new and has NFSH and long mot, it's covered 31000 miles.
I had the leather/ electric upgrade pack with the fast back fitted from new, i also had a toe bar fitted so i could toe my trailer.
It's in VGC as this has not been used for work.
£12000
Discussion Starter · #2 ·
I'm looking for a Vauxhall Vivaro 115 or something similar if anyone wants to swap.
way not try a nissan gts-t it is a 1997 spec is ENGINE
TRUST TD06-25G TURBO KIT
SS TOP MOUNT MANIFOLD
HKS FRONT MOUNTED INTERCOOLER
APEXI POWER FC AND COMMANDER
APEXI AVC-R BOOST CONTROLLER
APEXI 2 BAR BOOST GAUGE WITH PEAK HOLD
UPRATED FUEL PUMP AND FUEL REGULATER
HKS TRIPLE PLATE CLUTCH GD PRO
DYNAMICALLY BALNCED CRANK AND FLYWHEEL
DECAT FITTED
1.2mm HEADGASKET
TRUST INDUCTION KIT
TOMI HIGH LIFT CAMS DURATION 256, LIFT 8.5
TOMI ADJUSTABLE CAM PULLEY
NISMO 550 INJECTORS
Z32 AFM
ARP ROD BOLTS
ACP RACE SERIES BEARINGS THROUGHOUT
SPLITFIRE COIL PACK
OIL COOLER
RADIATOR COOLING PANEL
STEERING WHEEL BOSS KIT
REMOVEABLE STEERING WHEEL
BRAKE BRACE
KEVLAR CAM BELT
GROUNDING KIT
CARBON TOP MOUNT STRUT BRACE
JAPSPEED ENGINE DAMPNER
S/STEEL POWER STEERING COVER
S/STEEL FUSE BOX COVER
S/STEEL BRAKE RESEVOIR COVER
S/STEEL SHOW RADIATOR BRACKETS
S/STEEL RELAY COVER
S/ STEEL OIL CATCH TANK & WASHER BOTTLE COMBINATION
REDLINE SHOCKPROOF OIL IN GEARBOX
CARBON CANISTER AND PIPEWORK REMOVED
TURBO BEENIE HEAT WRAP COVER
POLISHED ENGINE COVERS
GTR GAUGE CLUSTER
Engine Misc.:
UPRATED BOTTOM END
ENGINE REBUILD BY ROD BELL
MAPPED BY ROD BELL
RE MAPPED BY ROD BELL ON 27/04/06
RE MAPPED AT CALUM"S BY SAM THE DENTIST ON 10/10/07
REMAPPED AT RISING SUN PERFORMANCE ON 28/07/08
Exhaust
JAPSPEED CAT BACK EXHAUST
JAPSPEED SILENCED DECAT
EXTERNAL WASTEGATE AND SCREAMER PIPE
BIG AND LOUD ALSO SPITS OUT FLAMES
Suspension, wheels & tires:
IMPUL NS-01 R RACING WHEELS IN GOLD
TEIN SUPER STREET SUSPENSION
FULL SET OF GTR R33 V-SP BREMBOS ALL ROUND
Exterior:
ILLUMINATED REAR SKYLINE PANEL
FULL BODY KIT ( 400R JUN )
400r Arch Extensions
CARBON BONNET
GTR REAR WING WITH CARBON TWIN BLADES
SMOKED NISMO SIDE REPEATERS
SMOKED NISMO FRONT REPEATERS
120 mm COLD AIR INTAKE FEED PIPE FROM FRONT OF BUMPER
KNIGHT RACER 6000K HID KIT( FOR HIGH AND LOW BEAM )
510 bhp and all the looks
Sounds very nice but need of toe vehicle though.
Still for sale
