1 - 20 of 52 Posts
Did you do any programming before install or just plug and go?
Bravo buddy. Might be doing this myself :bowdown1:
Discussion Starter #7
Middlehurst have got some virgin Nismo Club Sport ECM’s on eBay for £180 too.
You just connect it up, connect the battery with the keyfob in the slot under the steering wheel, turn the ignition on (no start), wait several seconds for it to marry itself to the BCM, ignition off, and away we go. I’m going to have to buy some Nismo badges at this rate :chuckle:
Other than having the Nismo rom on them what would be the advantage of fitting in of these to mine given I***8217;d be flashing my ecutek tune into it?
I get the tcm upgrade given the memory is bigger at 1.5mb so I could flash the newer years***8217; larger files.
Discussion Starter #9
You get some Nismo warning stickers :chuckle:
You***8217;re right of course. No benefit in outright performance, but my ECM is considerably prettier than yours :)
Currently, I have two spare ECM***8217;s and a spare TCM. I***8217;m crazy aren***8217;t I ?
What year is that TCM? Asking for a friend :chuckle:
Discussion Starter #11
The car was registered in 2015, but looking up the VIN, it was a MY16 car.
So it's the v2 of the 1.5mb boards I think.
It has an EcuTek license on it, but standard calibration flashed.
It also has 7 launches on the counter. No matter. It wasn't me guv! :)
The drive to work this morning was buttery smooth :)
Twas meaning the spare TCM as I might take it off your hands
Ah my bad. Took that as meaning you'd stocked up on a coupla bigger memory ones. Wishful thinking!
Discussion Starter #15
It won’t be long before another one surfaces. People thinking the hype is true, and writing themselves off in the process. Anyone can drive a 560bhp+ reptilian monster :smokin:
I’ll keep my ears peeled :thumbsup:
Be good if there was an upgrade for the early gearbox controller memory to increase the map size that could be loaded, in line with the later year cars
Discussion Starter #17
It’s an upgraded microcontroller with more internal flash. Swap the whole thing. Easy p; something about squeeze a lemon :chuckle:
Discussion Starter #18
The chip has approximately 1 million legs on it. I don’t fancy reflowing that, even if the chips are pin compatible :eek:
1 - 20 of 52 Posts
