1987 205 GTi 1.9 8v ( E reg )
2 months tax, 8 months MOT.
113k miles, but sound engine.
K&N induction.
Peugeot Sport GpN exhaust system.
New battery,
new HT leads,
new plugs,
oil changed every 2nd trackday.
New gear oil.
New clutch cable.
New Rad.
OMP 10pt Cage, bolted into welded in mounting points
OMP upper front strutbrace
OMP lower front strutbrace
KONI susp & springs with spare set of lower uprated springs,
Poly bushes,
GpA or N solid rear susp mounts,
Refurbed rear beam
White 15" speedlines (x5)
2x cobra buckets
2x 4pt 3" sparco harnesses
rear brake bias valve in car by handbrake
rear lines inside car
hand held fire extinguisher
COMES WITH:
4 spare TSW's with track tyres (new yoko's on two)
2 spare rear beams (1.9 GTi & 1.6 GTi)
Spare discs & pads
The car was bought 2.5 years ago off ebay as an MOT failure. It had a seized rear beam, cracked windscreen, no horn, and some corroded brake pipes.
The car sat unused for about 8 months before we decided what to do with it. Track Car!
The interior has all been removed. Carpets, roof lining, door cards etc… all gone. It still has a dash though, but no stereo!
The track car was built up over the winter 05, and MOT’d in April this year. A new rear beam was fitted, a new windscreen, new rear brake pipes, with in car bias adjusters and a horn (from a skyline ) were fitted. The electrics were also sorted out to the lights/indicators. This is a ROAD LEGAL TRACK CAR!!!
The car has been used on aprox 5 or 6 trackdays so far this year. Only problem it had was when Fiona snapped the clutch cable. The end of the cable fired off, and punctured the radiator. Hence new cable and rad above!
The bodywork – Its not the best, but isn’t the worst. There is a small dent in one of the front wings, some scratches on the bonnet, and some rough paint round the rear arches were I treated some light rust bubbling before it took hold.
PS…. This is a girlies track car… so wont have suffered as much abuse
reason for sale : selling both our track cars to make way for 1.
Where is the car located?: Edinburgh
What is the age of the car?: 1987
Asking Price: 1600
K&N induction.
New battery,
new HT leads,
new plugs,
New gear oil.
New clutch cable.
New Rad.
Poly bushes,
Refurbed rear beam
2x cobra buckets
COMES WITH:
Spare discs & pads
Asking Price: 1600
