Just thought i would share some info as there isn't much on this turbo. I know its not much power compared to some of the other cars here but it is what it is.
copied from freshalloy:
Sean(tyndago) is the man. Stayed up till like 1-2am finishing up the car. He inhaled quite a lot of the carbon monoxide, as did I. Ill take the worst hang over any day over this crap.... Thanks Sean! Also got to say thanks to RBmotoring and the great build and the great service!
Well, finally got around to tuning with Sean. Started with a heavy miss. Changed out plugs and clean coil packs and made literally, night and day of a difference. I gained 10hp on the same map and the dyno graph went front a roller coaster to a baby's ass. Then we couldn't get boost to go past 1 bar. I think i wired up stuff incorrectly. So im going to fix some stuff and hopefully retune this week.
Plan is to get the boost controller to work and go back and try to get 1.3 out of it.
Sean wants to try advancing the intake cam so i pick up some low end and lose some top but well worth the trade off. Also try the cooler plug 8.
kick ass 91 octane !
Stock untouched motor @ 40k miles
tomei poncams 264* 9.1mm in/exh
ported manifold
2860 -10's or 2871r - whatever you want to call it
ngk plugs
trust downpipes
hks hi-power fart canon
sard torque valve
divided twin turbo pipe
sard 800cc inj
nismo adj fpr set at 43 base
tomei fuel pump
blitz super gay bov's
stock airbox
pics courtesy of sean's fb
ported manifold
ngk plugs
trust downpipes
sard torque valve
sard 800cc inj
tomei fuel pump
stock airbox
