1 - 20 of 58 Posts
Hi all, just started an R32 GTR build.
the car came from endless racing about a year ago.
the car cosmeticly was not bad. but will need a lot doing.
engine wise it has an R34 N1 bottom end and hks top end (cams turbos)
problem was l brought the car with a broken cam belt.
my idea is to pull the engine remove the head and see what was broke bent or smashed.
Discussion Starter · #2 ·
engine out head off and lm a very lucky fella.
8 bent valves. not a mark on the pistons.
started to strip valves from head and found it to be completly worn out, and in need of a complete rebuild.
need to order parts for head. also considering oil pump upgrde, extended sump.
time to think.
while lm getting prices for parts. lve decided to strip off the sub frames. and get rid of anything not required.
removed all the pipe work and the 2 big solinoids for the Hicas system. it had an lock out bar but everything was still left in place.
l would post pics but for some reason lm not allowed.
today running braided lines for fuel sustem
Defo get some pics up buddy, a picture says a thousand words!
bob
Discussion Starter · #9 ·
dave1983 set those pics to ya
waiting for delivery of
getrac 6 speed gear box + transfer box
conversion front prop, rear prop and gear stick
carbonnetics twin carbon clutch 1350 press plate 800 bhp max + type "R" drive cog.
solid aluminium sub frame bushes
lll update the list as l order it
There you go mate:thumbsup:
Dave1983
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Discussion Starter · #11 ·
thanks for sticking them up for me dave1983
Discussion Starter · #14 ·
tomei oil pump
tomei oil Gallary Oriffice
nismo low temp thermostat
supertech Daul Valve Springs + titainium Retainers
tomei Valve Guides
tomei 1mm over inlet and exhaust valve set
supertech valve seals inlet + exhaust
lll update this list as l order it.
Good work so far....keep the pics coming
TT
Discussion Starter · #16 ·
driftworks solid aluminium sub frame bushes
driftworks solid diff bushes
rear adjustable camber arms
rear adjustable traction arms
front adjustable camber arms
front adjustable tension rods
polybushes rear hubs
whiteline adjustable sway bars
tomei oil pump
tomei metal head gaskets complete set.
supertech Valve Guides
Tomei inlet and exhaust 1mm over valves
N1 water pump
gearbox and shafts have arrived.
suspension parts are all coming from driftworks this week l hope
the rest from the states they will post this week l hope
thats a big list mate wish my other half let me have more pocket money haha :) if you ever need a hand give me a nudge and ill come up.
wardy
Discussion Starter · #18 ·
hi wardy get some good prices shopping around especially state side just now
powerhouse racing on this site 20% discount on tomei gear
Discussion Starter · #19 ·
just a little update waiting on parts deliverys. just been stripping rear subframe and cleaning it up ready. mean while the wife is keeping me busy with flat packs. hope the deliverys come soon and save me.
Discussion Starter · #20 ·
Parts have started to arrive it like christmas everyday somthing has arrived.
got a few pics and will post them as soon as lm able.
1 - 20 of 58 Posts
