They will fit okay on the standard rim mate but you may have problems with the diff because of the difference in rolling radius with the standard width front tyres.Hello
Would 305/35/20 tyre be ok for stock rims rear?
Can buy 2 P Zero to a really good price but would like to know they will be ok?
Have stock size in front.
Have seen a few the use 305/30 but not 305/35 thats why I ask
Its just under 2% differns from stock so are you sure that would cause a problem?They will fit okay on the standard rim mate but you may have problems with the diff because of the difference in rolling radius with the standard width front tyres.
I'm not sure it will cause a problem mate. The question is, are you prepared to risk it on a £50k car for the sake of a few hundred quid?Its just under 2% differns from stock so are you sure that would cause a problem?
No thats true but IF they would be ok I could save those money for something else, for ex downpipesI'm not sure it will cause a problem mate. The question is, are you prepared to risk it on a £50k car for the sake of a few hundred quid?
Btw the tyres Im putting on is the Pirelli P-Zero so no budget tyreThe size might work. They'll fit and so long as the front and rear are fairly well matched, should be ok.
Personally, there's no way on earth I'd put budget tyres. On the gtr. I know mist people don't consider hankook to be budget any more but the gtr makes very significant demands on its tyres. It produces an rare combination of weight and extreme longitudinal lateral grip as well as acceleration and braking. It also us designed for run flats so at least needs very much reinforced non run flats.
You are saving mobley on the THE single most important component of the car. I don't get why you'd spend money on all that performance potential then handicap it with cheap shoes.
If you want yo save, at least buy the toyos which have better grip than standard. Or consider the mpss for under £1000 as listed recently.
