Hi all, contemplating moving battery into the boot of my r32 gtr like the r33. Never having really looked at the R33, where do nissan route the wiring from front to rear? And do they run a similar setup wiring wise.. ie, instead of a battery, use a distribution point under the bonnet or is the wiring completely different ?
Any pics would be great :)
Cheers :)
Skyline Section Manager
I've moved my battery into the boot.
I used welding cable with a soldered eye for the engine end bolted onto another soldered eye on the original cable. I ran the cable from the engine bay into the inner wing, along to where the loom enters the car, into the car, across to the center console down the center console, under the carpet, under the rear seat and throught a hole on the rear bulkhead into the boot. The battery is held in place with a racket strap.
