Possibly, but the pads may not sit well on the discs. You can check the pad gap at full retraction with a ruler with the calipers off, or with a piece of wood 28mm thick. Obviously you will need to find some means of moving the calipers away from the CL of the hubs an appropriate amount, which given it won't be much could be tricky. Radial mount calipers are much easier to deal with than the stock lug mounts.
