sorry bringing this old thread up
So here is the thing i am looking to find out , looked all over web but no exact answer
right now i have 350Z with factory brembos on it, car is going to be sold before my 94 R32 GTR gets delivered from Japan
was thinking to remove these Brembo Calipers + Rotors from my Z and use them on r32 gtr ??
by this chart front Z brembo rotor offset is 4.75mm shorter , i can use that size spacers between caliper mount hole and hub mount hole if needed no problems i see here , rear rotors seams to be identical in terms of offset 0.5mm thats nothing , also read that bolts are m14 and need to be redrilled
So after all these can someone give me straight advice if i should keep them ? or it needs more than that to be done? if someone have done this exact swap plz wright you thoughts
these Brembos are free for me , i will put standard non brembo brakes on 350Z and sell it that way
Thx
Dato
