i have for sale a pair of 356mm discs.
they come with alluminium bells. i think the discs are endless and the bells are gtc.
they were used for half a mile or so (they were a tight fit so i had to run them to make sure they were compatible with my alcon calipers. well, they weren't).
for you guys to have an idea of compatibility i will show you pics. the only difference was the bells. the endless discs sit a bit outward than my alcon discs.
my alcon discs
my endless discs (the ones that are for sale). they only have 1 slight mark (1/4mm deep or so) of touching the metal pieces of the calipers.
ignore the drawings
300£ plus shipping for the pair.
i believe they could fit, but i think, that not with stock mounting brackets.
i think you would need larger ones because the brake area sits a bit away from the center of the wheel.
if that makes sense...
the width of the discs is 30mm i think
yea i know what you mean, i was looking for direct replacement but thanks for the quick reply
alex
