I have wanted a skyline for years, and about 6 weeks ago I finally got my dream car and it is fantastic, but the wife hates it, so much so she refuses to get in it as it makes her feel ill, so sadly it has to go.
360.1bhp and 265lbft @7300rpm on the standard ecu and 383.6bhp with 292.5lbft @7050rpm on the JES chipped ecu.
The basic spec is:
Stage 1
JES Chipped ECU
Uprated Downpipes,
Decat (with original cat to go with it)
Brand New Stainless Cat Back System (with 4" tail pipe, not to loud at idle or cruise but roars when on full chat )
Apexi Filters
Apexi AVCR (set to 1bar, altho this could be negotiable).
Greddy 60mm Electronic Memory Boost gauge (negotiable again)
Greddy 60mm Electronic Memory AFR gauge (negitiable again)
Panasport G7 10 x 18" Rims with Brand New Toyo Proxie 275/35's on the rear and nearly new Fk451's on the front (275/35's again)
Skylabs Torque Split Controller
New SR Street shocks and Springs
Red Stuff Ceramic Pads and Groved discs
Oil Filter Relocation Kit
Oil Cooler
Polished Rocker Covers
Polished Twin Turbo Pipe
Nismo Gear Knob
Nismo Twin Plate Clutch
Also has the Standard ecu with it.
Oil pressure is spot on, when started from cold it climbs to 5.5/6bar and when it's warmed up it drops to just above 2bar at idle, when driving below 3000rpm it's around 4bar and when giving it some it's up around 5 - 6bar again.
It has some history with it, Bimta cert from when it was imported in 2004 and is HPI clear with cert aswell.
Cat 1 alarm fitted, again with cert.
Bodywise there is some stone chips on the front bumper and splitter and other than that nothing worth mentioning.
Interior is spot on, dash is almost unmarked, just a few bits of sticky stuff on the lower dash which would come off with a bit of time and effort if it bothered you.
Seats are as new.
Gear gator needs replacing as it's worn which is a common problem with the nissan leather gators, altho the handbrake gator is fine, these are about £20 a set, just haven't got round to ordering a set yet.
Other than that I can't fault it to be honest.
I love it, but it's no good to me if the wife won't get in it.
Will accept £13,000 cash for it as it is,or will accept £11,500 without the stereo, boost controller and both boost and afr gauges, the blitz turbo
timer (altho I have an unbranded 1 that I could fit for you) and the skylabs
torque split controller removed. I would also be removing the new cat back
exhaust sytem and refitting the old stainless system that was on the car
when I bought it, the system is well made just the tail pipe isn't as nice
as the current one (it doesn't affect the performace as it's the same sized
system).
Will also consider a PX or Swap for the right car (sorry no skylines as the wife hates them
Tax is end of october 06, and Mot is Feb 07.
Any questions feel free to ask.
The basic spec is:
Stage 1
JES Chipped ECU
Uprated Downpipes,
Apexi Filters
Oil Cooler
Nismo Gear Knob
Seats are as new.
system).
