hey guys, i was jus wondering if anyone here would happen to know exactly how to wire up a cross-over switch to my r32 gts-4. I have one already wired but doesnt seem to be working right, it crosses over to 4wd mode for about 3sec max before disconnecting itself and sticking to rwd. So in other words ive lost my 4wd mode. :(
Its obviously not wired up properly and is interferring with another connection. If anyone could give me a diy instructions to the proper way id appreciate it alot.
Steve.
so basically all u want is a switch u can flick from the driving position, that will enable and disable the 4wd when wanted? if so, its as simple as wiring a switch in where the 4wd fuse is located.
yea thats the simplest way i wouldve thought of, but many other ppl are telling me these different ways. My current setups with wires are messed up, and is connected sumwer different. So its jus simply locating the two red wires i got and putting them straight into the 4wd fuse. cool :)
Thanx,
Steve.
