1 - 8 of 8 Posts
Looking for a plug and play 4wd controller for an R33 GTR, so i can switch to rwd mode...
You can't switch to rwd unless you lower the base pressure of the system by adjusting a screw on the solenoid.
I had some strange home made set up in my 32
Would go from 4wd to 2 at flick of a switch
Was really neat
As above, you can't switch the R33/R34 to RWD mode like you can on the R32 by pulling the fuse out.
The one Matty is talking about is a switch wired to that same fuse so you can switch it on/off.
When i pull the fuse out it goes into rwd no problem but doesnt work on a switch for some reason...i have to remove the fuse, then turn the car off then back on again for it work...
Discussion Starter · #8 ·
1 - 8 of 8 Posts
