My friends R33 GT-R V-SPEC has a problem with his 4WD. It is RWD now.
He has tried to bleed the system.
He tried to force the pump to work and it does.
But when the ignition/engine is on the pump only shows 5 volts.
He checked the fault codes in the boot and it showes:
Code 66, side G sensor and circuit
What does this mean?
According to the owner before my friend, the 4WD problem started when they had the gearbox removed.
But when we checked the 4WD light, the bulb was removed from the cluster. Fitted a new one now and it is always on.
So even he could had this problem before the gearbox was removed.
