Hello,
Couple of days ago, i started having a 4WD problem which i found out to be attesa code 35-ETS Fail Safe Solenoid and Circuit.
Then i noticed that when i tried to start the car again, there was an engaging or disengaging action from the drive system and the error code changed to 32-ETS Solenoid and Circuit.
I have checked the ETS actuator relay and can confirm that it is ok.
I am sure that the Control unit is not f***ed.
My last option is to try and bleed the attesa with the hope that this could be the problem.
I was wondering if anybody have had a similar problem and would be able to shed some light on this.
Regards
TY
