I bought this new and the description said it was for an R33 GTR. However when I've come to fit it it is about 40mm to short. I am assuming now it's for an R32, but could be GTS.? I am not sure so I have added all the measurments onto the picture if you need to check it will fit first.
(measurements in mm) Core is 52mm thick.
There is a sensor bung at the bottom left hand side - it has a cover screwed in in the picture.
I had already fitted my electric fan to it before I reaslised it was not tall enough so I could not send it back. So it does have 4 small holes where the fan bolts have been pushed through the fins.
£90 collected or extra £10 for DHL delivery.
Cheers,
Ant.
Cheers,
Ant.
