I've only had my GTR on the road for two months and it's gone bang again, just a couple hours ago. Got towed to the shop and I'm at work - they spoke very optimistically and said it was just a dead fuel pump, and are currently fitting an uprated Apexi unit for the low low price of USD$550
I am far more pessimistic and I don't think the car will be running tonight as they promise - here are the details:
was having a run down the highway at a spirited but not WOT 160kph, held that speed for maybe 30 seconds, cruised down to 100kph, then found that the car would not respond to the gas pedal at all. A paranoid look into the rear view mirror, and yep, I'm laying down a huge smokescreen, just like the last time I blew my engine. However, unlike the last time, the engine stops completely. I coast over to the breakdown lane. No smoke, no leaking oil (like the last time I melted a piston). But the engine won't turn over - the starter motor goes and the fan spins, but no sound of anything inside the block moving
I did have a hard thrash with the car putting a Maserati Coupe to shame last night, but the car ran just fine this morning heading to work and not a problem at all this afternoon until it just conked out.
I have a feeling it's piston rings that are gone (my PFC recorded a knock spike of 50) and worse, something has seized up good inside the block. I did take a good look at the oil and although a bit dark, it was still perfectly transparent. It did smell a fair bit like gasoline however, which I'm guessing isn't good.
If the causative factor was the fuel pump dying, wouldn't it have just gone out all at once, or could it have dribbled fuel for a bit, causing the engine to run very lean and then my piston rings go out? But if I had det, surely I would have gotten a knock reading higher than 50 - I've seen up to 117 on it before!
thoughts? or just some prayers might be nice too.....
