1 - 6 of 6 Posts
Please let me know if you have some for sale and at what cost! :thumbsup:
87mm is too big as just had block done to 86.5
Need them very quickly too....
You need pistons to be able to correctly size the bores, different pistons need different clearance dimensions, depending on material/design. Some even go as far as honing each bore to individual pistons in a set.
Yer, I need 86.5 though, because if I have any problems in the future I can then go up to 87mm!
Just for security and my sanity! :bawling:
|Ring us on Monday , we have 86.5mm Pistons in Stock. Forged Pistons with
N1 thickness rings. They are £575-00 + vat a set.
But you will have to check Bore clearances carefully, you normally bore the block to a piston size plus clearnce.
how quick is quick?
Can get wiseco but probably not till 2-3 days - asked supplier if he had stock but he doesnt
1 - 6 of 6 Posts
