Right think its time for my 200 to go i will miss it but im ready for a change (im after a 33 gtst while the wife is saying yes:clap: ), The car has done 87000 miles but had a engine with 35000mile fitted 10000 ago and also converted the car th a manual about 8000 ago both these jobs were carried out by my friend who owns lincoln turbo centre as were alot of the other mods and services spec:
Engine
External Wastegate Screamer Pipe exiting under car
Stainless Steel Manifold (ported and polished)
Boost set @ 1.0bar using Dawes device (manual bleed valve)
Forge V.T.A. Dump Valve on Cold side
Bar and Plate FMIC (600x300x76mm)
Custom FMIC Piping
NGK Iridium Spark Plugs
FSE Fuel Regulator
Fuel Cut Defender
HKS Induction Kit
Apexi GT Spec full system with 4 1/2 inch tail
Apex Performance De-cat
THS Downpipe (not fitted)
THS Turbo Elbow (not fitted)
Nismo Oil Filler Cap
Nismo Fuse Box Cover
255ltr Fuel Pump
Transmission
5 Speed Manual (converted from Auto)
Auto LSD kept due to closer ratio
ACT uprated Clutch
Race Release Bearing
Chassis
Lowered 45mm on Eibach Springs
H&R Dampers
Dano Front Strut Brace
Uprated Bushes
Wheels
18" Multispoke Altec Alloys With Black Spokes and Polished Lips
Kuhmo 225/35 tyres (600miles ago)
5mm Spacers
Lightweight Wheel Nuts
Brakes
Ferodo DS2500 Pads
Exterior
Lifted Bonnet with Custom Cutouts & Black Mesh
Matt Black Meshed Grill
E-Tech Rear Spoiler in Gloss Black
LED Sidelights
Nismo Sunstrip
"Ripped" style Graphics on both rear 1/4's
Nismo Rear Badge
Nismo Side Badges
Apex Performance Clear Front Indicators
Apex Performance Clear Side Repeaters
Nomoken Rear Sticker
Interior
Graham Goode Boost gauge in A-Pillar holder
Carbon Fibre Speed Cluster
2x Carbon Fibre Fire Extinguishers
GReddy Turbo Timer (needs wiring in)
Trust Gear Knob
Hand Stitched Gearstick Gator
Apex Performance Sill Plates
Standard Leather Seats
I.C.E
Kenwood Head Unit
Clarion Component Front Speakers
Clarion Rear Speakers
The only bad part to the car i would say is that the front bumper could do with a spray and the bonnet has a key mark on it.
£5250 ono 07921554401
cheers Gaz
