Hey All,
I need someone's expertise on this - my 4WD light is lit up on the dash (and not going out). I've checked in the boot and the red LED flashes eight times - 5 slow(ish) flashes and then 3 faster flashes.
According to what I can find using the almighty seach button, these codes most likely apply:
1,5 Front right wheel sensor and circuit
2,6 Front left wheel sensor and circuit
3,7 Rear right wheel sensor and circuit
4,8 Rear left whel sensor and circuit
Is this right? Do I have a sensor problem? Or is my car flashing two different codes at me i.e. 5 and 3?
If so, where should I go from here? Any help or advice would be greatly appreciated as I'm somewhat confused! :confused::runaway:
Thanks!
(Its a R33 GTR)
