1 - 10 of 10 Posts
Just received one of these which was meant to be a direct fit but it's not. There are no plastic pins on the back so there is no way to mount it. I don't want to screw through it, I bought it because I wanted to keep the interior as factory as possible so don't want screws hanging out.
The finish is great just annoyed about the fitting. Any ideas on what to do guys?
i dont think any pod is a direct replacement
(on the a pillar)
even the Greddy ones had to fix to something
so you have to screw those ones into position but there is a little fixing kit with the trust ones.
they will all have screws the screws wont be hanging out if there tightened ;)
I have one a twin it looks good imo.
yes gauges on the pillar looks the dog but it has to be screwed on which i didnt want to do. i sticked it on the dashboard instead using double sided tape :D
Mine is a full a-pillar replacement not just a pod, it looks awesome but in the below pics its hanging off...
Where do i put the screws in then? What do they screw into?
Sorry to revive an old thread, but where did you get that a pillar gauge pod from?
Thanks,
Chad
1 - 10 of 10 Posts
