1 - 14 of 14 Posts
hi all,
my car is due for its m.o.t soon and the hicas light is staying on all the time. what i need to know is if it is possible to blag it through the m.o.t with it on or will i need to sort it. and if not and i need to sort it what do i need to do to sort it. any help would be appreciated many thanks. scott.
Have you change steering wheel or have you done something else under dash? There might be just ground wire failure. Of course it can also be broken.
hi. not done anything to steering wheel of anything around the dash area. so i'll go with the its just broke bit. thanks
Do you have a power-steering fluid leak?
I honestly don't know for sure (someone help me out), but will the HICAS light come on if the P/S fluid is low?
Justin
I think the 33 has an electrical HICAS system and doesn't use the PAS fluid.
Also doubt that a missing HICAS bulb would fail the MOT (like ABS would). Hopefully a MOT tester can clarify. Though there's a problem somewhere that needs fixing..
Did the light just go out or did it flicker for a few days then go out?
My money is on low power steering fluid in the front resovoir also check the fluid in the boot (right hand side behind cover)
Just like to add my suggestion was a quick hack to get through an MOT; there's obviously an issue which needs addressing after that.
Discussion Starter · #14 ·
hi,
thank u all for yr input, i'll try the p/s fluid first if not just hope it goes through the m.o.t and then look at maybe a lock out bar etc. again thank u all for yr wisdom. scott
1 - 14 of 14 Posts
