1 - 20 of 42 Posts
Hi, we been really quiet on here over the last few years still very busy working on all the Skyline models, doing a lot of rust removal work on the 33/34 models. Will post some pictures up of our repairs later.
We have been working with our business partner in Croatia Auto Partes the owner has a few GTR's built by Abbey Motorsport they also specialise in restoration. We are working on providing a rebuild service on all the Skyline models.
This includes shipping the car to and from Croatia. You will be kept up to date with progress via a hosted picture library.
Working on a price schedule at the moment.
We have owned a R31 Nissan Skyline for sometime an Autech model which is 1 of 200 built , it was getting a little tired so we shipped in out last year;
few pictures of whats going on so far.
Keep looking back for updates.
Discussion Starter #4
We have some 32GTR bare shells that are going to be rebuilt hope to have these sorted for mid year next year will be a good base point for a rebuild of a tired worn out 32GTR.
Discussion Starter #7
Got a few more pictures to get posted up , just lack of time at the moment;
But a teaser for you guys;
That looks mint underneath I want my car to look like that!
Discussion Starter #9
We can make your car just like our R31.
Looks like the same rear setup as a Hako. Any idea how good it is, how effective it would be at putting down big power?
I am thinking its not a good design as if I have a Hako project I was planning on fitting R32 or possibly S14 rear setup? But perhaps the stock setup is better than I think and I would just have to fit a stonger diff? Looks like that uses an R180?
Nice work so far btw.
It's a 'long case' R200 diff, basically the same as came on your 260Z from the factory, but with different driveshaft joints.
You can fit a 'long case' R200 into a C10-series ('Hakosuka') Skyline body quite easily. It just requires a custom crossmember, available from the likes of Kameari Engine Works, Rubber Soul, RS Start, Victory 50 etc.
Discussion Starter #14
This is amazing! What sort of cost is involved?
Jags all depends what condition your car is and how much you want done to your car.
Well, the R200 is definitely strong enough but I was thinking more of the suspension/control arm setup and how effectively it can deploy the power.
I suppose it depends what kind of power you are talking about, and how you want to deploy it.
Both the C10-series and R31-series Skylines were used effectively as race cars by the factory works teams - C10 in PGC10 and KPGC10 form as Touring Cars, and R31 as HR31 'GTS-R' in Group A, all with the same basic semi-trailing arm layout. They managed to make them work well enough but it's hardly what you'd choose to use if you were starting from scratch and without homologation/series rules to conform to. Modifying the C10 rear arms to make them adjustable for toe and camber and installing rose joints makes a big difference though. You can buy a kit to do this yourself, or buy ready-modified rear arms on an exchange basis.
R32 and S14 a step up for sure, but mounting such in a C10 'shell is a fairly huge job and all a bit pointless without major strengthening of the 1960s design/construction bodyshell. Unless you build a multi-point cage into it - picking up on the suspension mounts - you end up with a situation where your bodyshell is effectively the fifth, undamped, spring.
Are you planning a C10 project then?
Good Info
Yes, possibly, can't decide beetween a C10 (GT-R Rep because I could never afford a real one), MK2 Escort, FD3S, or another 260Z, I was considering an E30 M3 for a while but I prefer the style of the option above so think I can rule that out. I think the C10 has the best style of that lot but its also the most expensive base and the hardest project to undertake. I was planning an RX-7 with a quad rotor but haven seen the price of a quad rotor setup theres no way I can afford it.
If I get a C10 then it would be full on long term build with chassis reinforcement included so it would probably make most sense to fit a better rear subframe, it actually doesn't look that hard to make one fit.
Discussion Starter #19
Nice job.
Are you doing zinc coating/plating yourself?
Car is being rebuilt in Croatia.
Guys can we keep this thread about the R31 please , good to chat about other cars but makes the thread harder to follow;
Discussion Starter #20
Few more pictures , will add pictures to separate posts to keep pictures in series;
The intercooler cooling duct was rusty so we repaired the existing duct;
1 - 20 of 42 Posts
