1 - 18 of 18 Posts
This thread is specially for Vihis but perhaps it als might help others who want to install a used Abflug rear diffuser :)
heatshield in front of tank
heatshield passenger side tank
bottom of spare wheel well (bolts, you need to use washers here as spacers so the diffuser will be level; Ville just use the bolts with washers as they are assembled, this way they were fitted on my car which should give you a good start:thumbsup:)
driver side rear suspension/subframe
inner side driver side rear quater (plastic cover)
inner side rear bumper where metal bracket is attached
passenger side rear quater underside
If there are any troubles, just shout :thumbsup:
Cheers,
Leo
wow, alot of work to make this thing fit
all i needed to make for my TS diffuser were these ;
and even then the 2 C brackets weren't ''needed''
the advantage with the ABflug is that you can keep wathever "mudguards" you want along with the diffuser
with the TopSecret, you have to use their mudguards because they hold the diffuser
1 - 18 of 18 Posts
