just had my abs pump repaired and the ecu side of it aswell and still have all the fault codes up,do any of you guys think it could now be a wheel sensor??
Who repaired it?
Hi Dudservr,
Control units did the pump,they dont do ecu repairs so it had to go to ECu testing for that side,they reported there was no faults on that side of things,if you read my earlier post it explains everthing that has happened so far,thanks for the reply i need someone to help with this one .its posted under UCU.thanks
