I've got a bit of a problem with my brakes, we're removed the ABS completely, a line now comes out of the master cylinder into a T piece, from that a line goes into each front caliper, another line comes out of the master cylinder into the connector block for the rear brakes on the front offside chassis leg, (just below the master cylinder).
We've bled the brakes, (twice), but still only the front brakes lock up, on the ramp with the car on wheelfree bars the rear wheels will lock enough so that you cannot turn them but out on the road they will not lock up no matter how hard you stand on the brake pedal.
It's as if it needs some sort of brake compensator, but I was told it was part of the master cylinder?
Anyone got any suggestions?
Alex B
Alex B
