AccessPORT User Survey 2010
At COBB Tuning we are always working to make our products perform better. We do this by improving ease of use with intuitive menus and features or increasing the performance and enjoyment of their cars with our Off the Shelf maps.
To that end, we want to know what you like about the AccessPORT. What features can you not live without? What features don’t ever get used? What would you change about the AccessPORT to make it better? This is your chance to sound off. Your input will help determine the course of future AccessPORT development.
Please respond to the survey below. Feel free to add in your own comments and criticisms. Would you like to see a feature or function added to the AccessPORT? Let us know. Now is your opportunity to tell COBB Tuning how we can make the AccessPORT better than ever.
Thank you for participating in our survey. As a company of automotive enthusiasts, we endeavor to build products that other automotive enthusiasts will appreciate and enjoy. We will be monitoring and participating in this thread so speak your mind. You can respond here or send us your responses to [email protected]
COBB Tuning
AccessPORT Development Team
1. What is your favorite AccessPORT Feature?
2. What AccessPORT features do you use on a regular basis?
3. How often do you use your AccessPORT to change maps?
4. How often do you use your AccessPORT to data log?
5. What are some of the features you never use on your AccessPORT?
6. What are the AccessPORT features you cannot live without?
7. If your AccessPORT only had 5 features, what would they be in order of importance?
8. What features would you add to the AccessPORT?
9. What is your opinion of COBB Tuning’s Off the Shelf (OTS) Maps? Do you use them? If so why? If not why not?
10. What maps do you use most often? What maps do you never use? Which maps would you add?
OK I'm back after the winter break.... Took the car out for the first time Yesterday and reminded myself how great it is.:D
So catching up on the Forum posts came across this and was suprised at the lack of responses?
So here goes...
Well has to be the ability to easily upload new maps.:)
Number 1 is loading new maps
Number 2 is datalogging
Number 3 is uninstalling for a service.
Depends on what phase we are in. When things were developing was sometimes several times a day. Now that things have settled a bit it tends to be triggered by various motoring events so more like once every 2 weeks.
Every time I have uploaded a new map, or am running on track with a new map.
Most are used, have only rarely used the fault code stuff, but very pleased it’s there for when it’s needed.
Uploading maps and data logging.
Uploading new maps
Data logging
That you are in control and that it can be installed and uninstalled.
That it can be upgraded over the net.
Fault code resetting
Setting of clutch capacity & touch points.
Resetting of tyre pressure sensors.
Adjusting launch revs / other launch related parameters.
Logging of the transmission temperature.
Disabling of the pedestrian protection system. (For when on track….)
A detail… But it would be good if when datalogging if the map name was included in the saved file name. If you do a lot of logging it’s easy to get confused.
Date and time would also be nice, but realise there is no RTC.
Not for the AP but, a program that we all use that graphically displays the data logging results, to enable quick comparisons and easier sharing of data
I used the initial release Stage 1 & 2 maps, and was very pleased with them. However since Ben / Thistle have come out with their maps have been through several generations of those. 99Ron, WG duty by RPM, WG3 and am about to try the latest V2 gear_tps map. Car has been in the garage for 4 Months waiting for the nicer weather…
Whatever is the latest Ben / Thistle custom maps, are used most often. I uninstall and put the standard map back when the car goes in for a service.
To be honest I am very happy with what has been achieved so far. Have yet to try the Gear_TPS map, but suspect that a few variants on that may be good for some special situations. Drag Strip mode, Twisty small circuit, Fast sweeping circuit etc.
Have never used anti-theft, valet mode or economy mode….
I do not know if it’s possible but would like a map that would allow me to start with VDC off for the best get away but then automatically switched into Transmission Race mode?
In summary it is a fantastic device, exactly what I would have wished for, but would never have expected it to exist. :)
Rich
