Depends on the boost you want to make, they are no different other than a harder spring, if you want over 22psi then they are the go.
Forgot from your rebuild , what tubs your using but if new tubs(-5/7/9) then Garrett are up to the job
Collar issue best having a custom made, I'd personally have a custom under size by .003 made.
Any decision on ecu?
I got some time for the ECU, once the engine is built I will run it in and then start with injectors, ECU and upping the boost.
Will be -5 based but speaking to a turbo specialist we are looking at doing some mods to make them spool up a bit quicker but that is not 100% decided yet.
Where did you get your collar made up? I have about 0.017 and 16 clearance I would ideally like to have something like 0.010 similar to that of Tomei.
So they are good for around 1.5 bar? if so I will leave the HKS ones :)
