just had my ride height adjusted - Teins in front, which were a breeze to set, and in the rear, I have Mine's branded Ohlins (without external reservoir), and the shop said they couldn't adjust them. Not clear if they meant "they can't do it" or "it's impossible" - in Korean you use the same words for both meanings
The Mine's coilovers didn't have the fine threading that most coilovers do, but the spring collar did look like it was mounted on a thread, although the thread was pretty wide (maybe up to an inch between threads). Do they just require special wrenches, or are these coilovers fixed height?
