HI guys
need some freindly advice
while tootling around town in traffic is it better for the car to drive it in lower gears or the highest gear as ive heard differing opinions.. ?
also is it ok when your parked up and in your car to keep the engine running on idle say for 1/2 an hour or so or should you switch engine off ?
and can you just start your car and drive slowly in the morning or when cold or do you have to wait till the oil gets past 70 degrees and then drive off ?
cheers SKY
cheers SKY
