Hi Guys
have not been here for a while life to demanding , I am having problem with hoses splitting .....i have upgraded them and they still split after a good work out ,also after the car is warm and i park up and then restart her the engine makes a horrfic sound and seems to rock from side to side as well as my gear knob , should i drive it there is no power in her and then all of a sudden clears and then runs normal. this problem only occurs after short runs ie a mile or 2 any advice ???
Discussion Starter · #2 ·
Hi Yer
the temp is at nomal but my oil pressure is higher than normal . the noise sounds like the exhurst is blowing badley also if you rev hard I get a lot petrol clouds .............does that help
Hi Jason
Yes it starts fine every time ( touch wood ) even after long trips its fine its only little trips then i have a choice either drive till it goes or leave it for a few hours
