running a fairly standard engine with only the following mods.
3,5" HKS full-dragger pipe all the way from turbo's
New uprated downpipes,
open HKS foam airfilter,
Nismo ECU.
I haven't mangled with the boost pressure yet, and it is currently running 330 bhp ATH.
I would like to pull between 50 - 100 BHP more. (or what ever more can be found in the dark corners
could I get that from just upping the boost? was told that it could run a safely 1,2 bar???
and what would the next step be?
what would you recommend me doing?
Nismo ECU.
