I have an AEM standalone ecu which will work on R32 GTST/GTR and R33 GTST/GTR. It is the wideband version so comes with a extra loom to plug a wideband sensor into it. It also comes with a 3.5 bar map sensor so you can do away with the AFM/s etc.
Here is a quick feature list :-
AEM***8217;s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle***8217;s factory ECU harness and requires no additional wiring or hardware. (Some adapting hardware may be required for non-factory forced induction vehicles.) Windows***8482;-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish ***8220;quick keys***8221; to any pertinent information during the tuning process.The AEM EMS***8217;s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
KEY FEATURES:
Installs in Minutes
Plug & Play Technology - No Wiring Necessary*
Uses all the Factory Sensors
Fuel Table Automapping
Base Maps Included
Programmable Traction Control
Onboard 512kb Datalogger
10 Cyl Sequential Fuel Injection
16 General Purpose Outputs
7 Definable Switch Inputs
Electronic Boost Control
Soft Cut Rev Limiters
2 Step Launch Control
Wet or Dry Nitrous Control
Definable Knock Control
Full Idle Control
4 EGT Inputs w/Fuel Control
16/32 Hybrid High-Speed Processor
Im looking for £550 for ecu with wideband sensor, usb to serial convertor and AEM CAS disc.
